Homemade ski/tube pylon-bar.
kryptonite
#1 Post by kryptonite » Sun Jun 05, 2011 3:13 pm
I'm sick of the stupid "Y" rope. It's a pain in the A**. I'm a good metal fabricator, so I'm going to build one out of regular metal. I'm not paying the $500 the dealer wants for one.
Basically what Curtis has on his, but I'm gonna make it out of round tubing for more of a factory look. I'll just paint it for this summer, then maybe this winter I'll get it powder coated.
Here is a mock up built out of wood to get all the angles and dimensions. That way I can get a cut list and know all the lengths and angles.
Ron Burgundy
Re: Homemade ski/tube pylon-bar.
#2 Post by Ron Burgundy » Sun Jun 05, 2011 3:15 pm
Nice. You could make a few bucks if you decide to custom make them.
kryptonite
#3 Post by kryptonite » Sun Jun 05, 2011 3:15 pm
The bottom will have a flat iron running from the front support to the rear support. That flat iron will then bolt through the crossmembers.
oldmn19
#4 Post by oldmn19 » Sun Jun 05, 2011 5:54 pm
Sounds like a plan to me, will probably be stronger than the $500 one also, as some of them just bolt through the plywood floor. :thumbsup
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
PlaynDoc
#5 Post by PlaynDoc » Sun Jun 05, 2011 6:05 pm
im interested in price, fully assembled, powder coated, if you are successful!
OR, you could be generous and provide a 'measured drawing' of the finished product, so the rest of us could measure for fit, then take plans to a fabrication shop for construction.
#6 Post by curtiscapk » Sun Jun 05, 2011 7:31 pm
nice glad I could be of service! I would think I get a cut for design engineering! :donno
The_Hellbilly
#7 Post by The_Hellbilly » Mon Jun 06, 2011 6:06 am
Mine is factory, but if you want addl' pics &/or measurements just let me know
2005 Voyager 22ft Tritoon
2004 Honda 135hp
rrhodes
#8 Post by rrhodes » Mon Jun 06, 2011 6:34 am
Also factory installed but works great.
2008 JC Neptoon 25TT
115hp Honda 4-stroke
2007 Suburban LTZ
Lake Murray, SC
kryptonite
#9 Post by kryptonite » Mon Jun 06, 2011 7:02 am
The_Hellbilly wrote:Mine is factory, but if you want addl' pics &/or measurements just let me know
Yours is different from most I've seen. That's the problem, no two transoms are the same it seems. That's why you can't find any reasonable aftermarket one available. That was the reason for the wood mock up first, so I could picture all the angles and such.
#10 Post by curtiscapk » Mon Jun 06, 2011 7:51 am
I think you have it down. And I love your speakers I was thinking of doing the exact same thing, That is if I get the fucker to run again.... :x
kryptonite
#11 Post by kryptonite » Mon Jun 06, 2011 12:22 pm
curtiscapk wrote:I think you have it down. And I love your speakers I was thinking of doing the exact same thing, That is if I get the fucker to run again.... :x
Yea, I put those speakers on this winter. We spend lots of time at beaches, so we are usually behind the boat swimming. Before to hear it in the water you have to crank it, then anyone that is sitting on the boat gets blasted away. I have the speakers on a separate amp, so I can turn them off and on.
kryptonite
#12 Post by kryptonite » Mon Jun 27, 2011 8:36 pm
Finally got some time to get started on this. Been busy with work, but now since it rained AGAIN, can't get back in the fields for a few days. So figured I could get her done this week. Took about 3-4 hrs to fab it up and weld it. Now just need to figure out some type of rope mount. Then get some paint on it and bolt it on!!!
#13 Post by curtiscapk » Tue Jun 28, 2011 5:56 am
That looks Great! Here is a close up of my ring you look more than capable to fab it :nana
GXPWeasel
#14 Post by GXPWeasel » Tue Jun 28, 2011 9:07 am
Haha. I am actually having one built by a guy here in town ( he has the tools, I don't) and it look very similar to yours there. I purchased a ski tow hook online for $13 ( stainless steel ) and I will just bolt it through my tow bar when I get it back home. Might give that a shot.
Looks great by the way, and I'll put pic's up of mine once I get it back too.
"Nauti Weasel"
2005 Beachcomber Islander 26
kryptonite
#15 Post by kryptonite » Tue Jun 28, 2011 4:49 pm
Here's some pics of it painted and with the rope mount on.
The rope mount I ended up welding a 3/4" bolt (cut the head off) to the top bar with a slight angle forward to keep the rope from trying to jump off. Then I found a bushing and put some washers on each side of it with a lock nut on top. This way the bushing can swivel so it doesn't wear out the rope.
