Water In Pontoons
Ron Burgundy
Re: Water In Pontoons
#16 Post by Ron Burgundy » Thu Jun 30, 2011 7:28 pm
Amosmoses33 wrote:One of them gave me the woosh and air came out....
the other not so good....water ran out of it for a good minute. I am going to replace the plugs and use plumbers tape for a good seal and see if it does it again this weekend. If it does, I'll be asking for some detailed help on how to pressure it up and find a leak.
Thanks!
One minute isn't too bad. It's not great, but could be worse. I had water drain out of mine for over ten minutes and it was about 45 gallons. If worse comes to worst and you need to patch a crack it's not too bad of a fix. You jusy need to find a competent aluminium welder.
Amosmoses33
#17 Post by Amosmoses33 » Fri Jul 01, 2011 8:40 am
No I guess a minute isn't too bad compared to 10 minutes. I am not really understanding how to pressurize the pontoon but I will worry about that next week if my leak continues. I found some brass plugs at walmart and wrapped them with the teflon tape and put them in this morning while it was still cool outside. Hopefully it was the plastic plugs. Everyone have a safe holiday weekend! I am excited, my first with my own boat!
2008 Bentley 204 Fish
90 HP Mercury 4Stroke EFI
Lake Lanier, GA
Go Dawgs!! Sic'em Woof Woof Woof!
Ron Burgundy
#18 Post by Ron Burgundy » Fri Jul 01, 2011 8:53 am
You should switch to SS plugs when you can. Brass plugs will eventually corrode your aluminium.
Woody
#19 Post by Woody » Fri Jul 01, 2011 9:03 am
Amosmoses33 wrote: I found some brass plugs at walmart and wrapped them with the teflon tape and put them in this morning.....
Uh oh......better get those back out of there before too long.
2019 Veranda 22 RFL 250SHO
jeffybear
#20 Post by jeffybear » Fri Jul 01, 2011 12:39 pm
Guys,
What's the purpose of pressurizing the toons? Seems to me any pressure I had in the tank has leaked out anyway. Do the toons need to be pressurized or is that just a natural thing that occurs with the weather changes?
"If 10% is good enough for God, then 9% should be just fine for the Federal Government"
Herman Cain - Aug 18 2011
1997 90hp 2 Stroke Merc
1997 Sun Tracker Fishin' Barge 21
Ron Burgundy
#21 Post by Ron Burgundy » Fri Jul 01, 2011 12:53 pm
jeffybear wrote:Guys,
You pressurize the pontoon's so that you can look for leaks. When the marina performed this test on my logs they sprayed them with soap and water so that they could see if air was escaping through any holes or cracked welds. The logs do not remain pressurized after the test. Although changes is temperature can create pressure inside the logs this isn't part of the test.
jeffybear
#22 Post by jeffybear » Fri Jul 01, 2011 4:03 pm
aha, so there is no magic to pressurizing the toons. This is exactly how they found my leak. Air, water and soap. Thanks Ron!!
spurhunter
#23 Post by spurhunter » Fri Jul 01, 2011 6:55 pm
I am getting water in both logs, the starboard drains for about 6-8 minutes after a couple trips. I am bummed about tring to find and patch the leaks. :(
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
Richard
#24 Post by Richard » Sat Jul 02, 2011 4:58 am
My logs have 3 plastic plugs on the top. One for each section. The plugs have a very small hole in them. I assume that is to let the logs breath without building up preasure with changing of tempuratures. I assumed all pontoon logs would have to have vents for this purpose. If you don't have a vent, it seems the log could expand and break a seam, therefore a leak accures.
Amosmoses33
#25 Post by Amosmoses33 » Tue Jul 05, 2011 9:20 am
Whats wrong with brass plugs? Why the uh oh?
Lake Lanier, GA
Woody
#26 Post by Woody » Tue Jul 05, 2011 9:40 am
Corrosion issues. A search on here will reveal some good discussion on the topic. :biggrin2
#27 Post by badmoonrising » Wed Jul 06, 2011 4:24 am
Yeah get rid of the brass plugs asap. The brass being the superior metal will cause your aluminum hull to corrode. Manufacturers use plastic or stainless so that's not an issue. When I restored my Starcraft, the guy used brass here and there. All the areas touching the brass had corroded severely. Enough to put 2 quarter sized holes in the transom.
GregF
#28 Post by GregF » Wed Jul 06, 2011 9:34 am
Galvanic Corrosion?
I have not heard of this thing. ;)
1974 Harris
70 HP 4 stroke EFI Yamaha
Red555
#29 Post by Red555 » Wed Jul 06, 2011 1:29 pm
GregF wrote:Galvanic Corrosion?
When dissimilar metals are in contact, there is a small electrical current that will erode one of the metals.
See link or google....
http://en.wikipedia.org/wiki/Galvanic_corrosion
Mike
20' Sweetwater with a 90hp Yamaha
Northeast Florida (GCS)
Amosmoses33
#30 Post by Amosmoses33 » Wed Jul 06, 2011 4:48 pm
I removed the brass plugs. The one on the left wooshed air like before. The one on the right didn't go woosh, but no water came out and I couldn't feel any water in it when i stuck my pinky in the whole. I guess I have some pin hole above the waterline or something that is letting it not hold pressure but is not getting water in it.
Thanks for the help.
Lake Lanier, GA
