Need Umbrella Mounting How To
ArkieBoater
Re: Need Umbrella Mounting How To
#16 Post by ArkieBoater » Fri Aug 10, 2012 6:00 am
Thanks again for all the replies, I may have to check out that umbrella from Sam's Club. I will be happy if it just don't blow away while I am sitting still, I don't have much faith in traveling at any
speed at all with it in the open position. Loyd, on a side note, my wife found a really nice pocket knife while wading between the islands out of Chicken Creek, normally the water would have been
probably 4-5 feet deep where she was wading. Also saw a really nice Colbalt runabout, probably around 25 foot at least, up on the rocks just south of Chicken Creek south ramp. Stopped up
at the Cookson dive shop ( they had recovered it) and it had torn the outdrive completely off and put a huge crack in the bottom of the boat towards the back, the owner of the shop said they
would probably total it for sure. It was around a 2007 with around 325 hours on it, it was a very nice boat.
Charlie
Lake Tenkiller , OK
2009 Sylvan 8522 with RPT tubes
2009 Evinrude ETEC 150
14.5 X15 prop
#17 Post by lakerunner » Fri Aug 10, 2012 6:10 am
If you ever need a good anchor Tim and Jason Little from Sixshooter dive for them all the time
GregF
#18 Post by GregF » Fri Aug 10, 2012 8:32 am
lakerunner wrote:
GregF wrote:That explains the difference. I use a market umbrella with a 35mm pole and hardwood stays.
I wonder if that winged top would fit on my frame?
Highly unlikely don't you think
On my last umbrella I replaced the top twice. They don't have to be exact, just close.
Capt Sully
#19 Post by Capt Sully » Fri Aug 10, 2012 10:06 am
GregF wrote:I put mine in a piece of PVC pipe, bolted to the console.
Looks like a mighty- fine PBR there.
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
idadell70
#20 Post by idadell70 » Sat Aug 18, 2012 5:06 am
I do not have a picture but I mounted in the floor a good quality flanged vertical fishing rod holder. It is flush with the floor. I drilled the hole for it immediately adjacent to a cross rib below and used a c clamp to clamp the rod holder to the rib for strength. It easily handles an 8 ft umbrella and covers the forward area of my 19 footer. As an added benefit I have one of the inexpensive " drop over the umbrella " mosquito nets .
2003 ODYSSEY 19 FT
1986 JOHNSON 50 HP
ELK TRAILER
