SouthBay pontoon Boat
Re: SouthBay pontoon Boat
#16 Post by curtiscapk » Wed Apr 10, 2013 6:53 am
cleatus wrote:Smoker-
Cutting the rear struts may work, or relocate them backwards onto the main top fence rail.
That elevated fence piece is what got you buggered up.
Nice Southbay btw.
Awesome Catch Cleatus!!!
cleatus
#17 Post by cleatus » Wed Apr 10, 2013 7:01 am
thx, glad to help somehow.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
smoker62
#18 Post by smoker62 » Wed Apr 10, 2013 7:43 am
Duh! I see now . I had a few guys on the lake looking at this with me and we all could only see cutting the rears shorter . None of us ever thought about the higher rail mount on the rear being the screw up. I did look at dropping them to the lower rail but for some reason I couldnt do it. I think my rear hatch on the port side sits over it . Cant remember since its been in storage for a while.
Thanks guys.
cleatus
#19 Post by cleatus » Wed Apr 10, 2013 9:18 am
"I think my rear hatch on the port side sits over it ."
yeah it does, you can see it in the pic you posted, you'll prolly have to cut the struts.
Yamaha F70
1roadking
#20 Post by 1roadking » Thu Apr 11, 2013 5:35 am
Shouldn't this be covered by southbay? It looks like the top was made wrong or shipped with the wrong rear struts!
150 yamaha 4 stroke
2012 tundra tow rig
smoker62
#21 Post by smoker62 » Thu Apr 11, 2013 5:55 am
Not sure who puts the tops on. Either way you would think they would know the rail mount in the rear is higher and adjust accordingly. I could probably get my dealer to do the fix but since he is 3 hrs away I will handle it my self. Take me about 20 minutes to drill out the pop rivet , cut the tube and remount the base .
Jenkins
#22 Post by Jenkins » Thu Apr 11, 2013 4:25 pm
Hi Smoker - if you end up doing a warranty on it, don't forgot there is a South Bay dealer just south of you on Chain of Lakes. Less than an hours drive from Kenosha. We bought our boat there and they do all the service as well - great group! Munson Marine in Fox Lake.
If you move the rear uprights, wouldn't your cover be messed up then? Where the collar opening is?
2012 South Bay 525CR
Merc 150 Fourstroke
I used to jog, but the ice cubes kept falling out of my glass.
ToonGuy
#23 Post by ToonGuy » Fri Apr 12, 2013 9:04 am
Jenkins wrote:Hi Smoker - if you end up doing a warranty on it, don't forgot there is a South Bay dealer just south of you on Chain of Lakes. Less than an hours drive from Kenosha. We bought our boat there and they do all the service as well - great group! Munson Marine in Fox Lake.
I would agree. I'm wondering if this top was going to be used with straps in place of struts because of the gate placement, but some one installed struts instead? I take it your struts are NOT adjustable (up and down)? What does the measure ment from hole-to-hole NEED to be on the front? I might still have a set of adjustable strust laying around...
Cycleman07
#24 Post by Cycleman07 » Fri Apr 12, 2013 9:48 am
Just trying to help.
here is a brand new 522CR with Bimini top mounted exactly the same as yours is.
http://www.boattrader.com/listing/2013- ... -101953711
smoker62
#25 Post by smoker62 » Tue Apr 16, 2013 1:11 pm
I keep my boat on Castle Rock Lake in Necedah. That is 3 hrs from my dealer in Milwaukee. I cant move my struts back because the hatch on the port side is over the rail , so no problem on my cover collars.
I cant tell from the pic what holes the front struts are in on the one on boat trader but mine are in the lowest just to get the top somewhat tight. It will be no problem to raise the fronts to the center hole , which will result in lots of slack, but then cut the rear tubes down to tighten the top and level it out.
I did a trial fit on the water last year and still enough headroom, of course I was drinking a few beers that day. My wife was the dd :drink4 . I think the tops for these multi level mounts come with shorter tubes in the back and mine just got the standard ones for a straight rail.
