#16
Post
by curtiscapk » Wed Jun 05, 2013 9:55 am
I'll be damn!!
evinrude2stroke
#17
Post
by evinrude2stroke » Wed Jun 05, 2013 11:18 am
lakerunner wrote:evinrude2stroke wrote:On the bracket. It also has to be level. Your kit should have shims in case you need them. Be sure to use stainless steel hardware.
Level on a side to side you mean? It doesn't on vertical because transducer is adjustable
When I installed my Faria Depth Sounder the transducer was adjustable for horizontal & vertical mount. It also came with shims
I didn't need them but I guess they supply them in case your mounting it in an unusual location. I remember the directions stressing that fact that it has to be level.
My Manitou only has one bracket which in under the ladder. I mounted it there and doesn't effect the ladder use and works great.
Dave
Drago
#18
Post
by Drago » Thu Jun 06, 2013 4:17 am
Our original was mounted on the pump bracket on the left tube. I installed the newer one on the transom in front of the engine. The water is much cleaner there and gives reliable readings to much higher speeds.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
