Factory Wax Coating on Premier Pontoon Toons
brockhamre
Re: Factory Wax Coating on Premier Pontoon Toons
#16 Post by brockhamre » Fri Oct 24, 2014 10:54 am
I used toon brite and it whitened them up nicely. I will try the polish to finish them off. Thanks!
BTW, any idea how much polish I need to get this done? the outside of the 2 outside toons only.
brockhamre
#17 Post by brockhamre » Fri Oct 24, 2014 11:00 am
Here is what it looks like before the polish and after the toon brite.
#18 Post by Bryden24shp » Sat Oct 25, 2014 7:13 am
I went through a quart and a half of Sharkhide polish. I am going to try the White Diamond on some touch up spots that need done. I took the shroud off that is above the pontoons and the plastic piece above the nosecones. I polished the outer sides of the outside toons and all three nosecones, on both sides, back about 6 feet. I still need to hit the back of the pontoons and the transom. I'm going to do the transom when the outboard is off for the jackplate installation. 1 quart of Sharkhide protectant is all you'll need. It goes on easy and doesn't take a lot. I did my Manitou and Premmie, trailer and my Prowlers trailer, still have about 1/8 of a quart left. I bought 2 quarts from Clint at Sharkhide, plus the cleaner and polish. When the shrouds are off would be an ideal time to install rope lighting, too. Just an idea!!!
PM me if ya need anything....
