urbnsr
#16
Post
by urbnsr » Fri Apr 29, 2016 7:30 pm
...And now I can't sleep tonight
Oh, well. The marina has security cameras, so I assume all will be well.
Or will it?...............
Paul
mpilot
#17
Post
by mpilot » Fri Apr 29, 2016 8:43 pm
Another thing to consider if it is on a lift is your climate. If it is going to freeze and you are leaving the boat on the lift you want to leave the motor trimmed down. Even a little water in the lower unit can cause big problems if it is trimmed up. Our Marina is about 70% down 30% up. I leave my inboard bowrider trimmed down and turned straight because of muskrats.
Post
by Bryden24shp » Sat Apr 30, 2016 4:06 am
illinoid wrote:At my Fil's marina someone stole all the props that were out of the water a few years ago...including the Sheriff's patrol boat.
We had a rash of that at Lake of the Ozarks a few years ago. They caught the guys selling them on Craigslist and Ebay. The PropLocks were selling like crazy that summer...
teecro
#19
Post
by teecro » Sat Apr 30, 2016 4:29 am
And if I want to steal the prop on a lowered motor how much extra effort and time will it take to trim the motor up?
Seon
#20
Post
by Seon » Sat Apr 30, 2016 4:36 am
My Yamaha F150 is up all the way but the skeg is partially submerged. Hate it but can't be helped other than pulling the Toon out every other month to power was the logs and skeg.
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
NonHyphenAmerican
#21
Post
by NonHyphenAmerican » Sat Apr 30, 2016 3:52 pm
teecro wrote:illinoid wrote:At my Fil's marina someone stole all the props that were out of the water a few years ago...including the Sheriff's patrol boat.
Yep. Most of the new motors I've seen have a trim switch on the motor.
So by the theory that they can steal the props, I guess the prop being gunky will deter them.
urbnsr
#22
Post
by urbnsr » Sat Apr 30, 2016 4:05 pm
Could the battery have a not-so-each to locate cut-off switch to further deter the prop pilferers from trimming the motor up? Or at least slowing them down. Just curious - I have the motor up to help them out
Paul
teecro
#23
Post
by teecro » Sat Apr 30, 2016 4:26 pm
urbnsr wrote:Could the battery have a not-so-each to locate cut-off switch to further deter the prop pilferers from trimming the motor up? Or at least slowing them down. Just curious - I have the motor up to help them out
Don't sweat the small stuff; most pontoon boats are running at best a 100.00 alum prop....
urbnsr
#24
Post
by urbnsr » Sat Apr 30, 2016 4:33 pm
Yeah - I do feel better with it raised out of the water. Especially since I understand why.
Tnx
Paul
Scott1
#25
Post
by Scott1 » Mon May 02, 2016 8:21 pm
On the Verado's they do not recommend storing the motor in the up position. The oil can get into the Supercharger and cause some big problems. If you do this, you are supposed to put the motor all the way down and let it sit for a minute or two before attempting to start.
2014 Bennington 2375 RCW with Verado 250 Pro and Simon Motorsports ECM upgrade to 325 HP
Tri Toon with ESP package
urbnsr
#26
Post
by urbnsr » Mon May 02, 2016 8:37 pm
That wouldn't be nice! I like NonHyphenAmerican's method to lower the motor as the first step before doing other things. I followed that yesterday.
Paul
