New Sylvan leans 2" to starboard at rest & underway
Henpecked
Re: New Sylvan leans 2" to starboard at rest & underway
#16 Post by Henpecked » Wed Oct 03, 2018 9:16 pm
Rick McC. wrote:
Wed Oct 03, 2018 7:57 pm
Our Bentley sits deeper on the port side, as the fuel tank is located at that rear corner of the boat.
I was a bit concerned at first about the possibility of water in the toon (bought it used) then realized that the bottom paint on the port toon goes up a bit higher, so it’s always been like that.
It seems to level out fine when underway.
Maybe they will provide "pin striping" to hide the difference.
Rick McC.
#17 Post by Rick McC. » Thu Oct 04, 2018 6:35 pm
Well, if you can’t tell, it doesn’t bother me, but it is less than the two inches noted by the OP.
After all; “physics is physics.”. :biggrin2
Doug07
#18 Post by Doug07 » Mon Apr 08, 2019 12:27 pm
I would be a little upset in that the tank should be center mounted if possible. That makes you carry 175 pounds or so of beer on the starboard side to get a level ride!
2018 SouthBay 525RS3.0
Yamaha 250
Marc K
#19 Post by Marc K » Tue Apr 09, 2019 9:20 am
And you see a problem with that? :lol3
