Low RPM at full throttle???
Re: Low RPM at full throttle???
#16 Post by margaritaman » Thu May 13, 2010 2:15 pm
I had the same problem once and I would get full rpm if someone pumps the bulb on the fuel line. It had a pin hole and was sucking in air so fuel was not getting into the carbs. The bulb was brand new and had a pin hole in it.
#17 Post by curtiscapk » Thu May 13, 2010 2:21 pm
Nice margarita I forgot about the bulb.... :nana
wed
#18 Post by wed » Thu May 13, 2010 3:21 pm
You might want to check the fuel line under full throttle to make sure it has not collapsed. I would look at the plugs...if it is running lean they may indicate some erosion (burning) of the plug surface which is very damaging to the cylinder, pistons, etc. Just something to consider.
2007 GMC Sierra
slowdog
#19 Post by slowdog » Thu May 13, 2010 5:07 pm
I had the same on my boat found a sticking float on the lowed carb. I had the carbs off about 15 times befor we found it .
GregD
#20 Post by GregD » Thu May 13, 2010 8:15 pm
I had similar problems with my 1995 Mercury/Mariner 40 hp (4 cylinder) two stroke several weeks ago. First problem the motor shut down and would not start, my son changed the power pack and also noticed the voltage regulator was burned. After changing these two items we put it back in the water and it would only run about 3600 rpms. He cleaned the carbs, put it back in the water, 3600 rpms. He changed the "trigger" (?) and now it runs perfect, 5600 rpms.
1989 Sun Tracker 24' Party Barge 1997 Honda 90
17' LakeSport w/ Yamaha F60
Many men fish all their lives without knowing it is not fish they are after" Thoreau
GreenGolfBall
#21 Post by GreenGolfBall » Fri May 14, 2010 5:37 am
Ok so we checked the coil packs...they seem to be fine. Spark plugs...still good. Fuel tank fitting...good. Looks like we're going to be rebuilding all 3 carbs. I like the stuck float idea...we'll check that when we rebuild. And also we'll be checking the voltage regulator. What is the "trigger"? Those are both great ideas and next in line for checking. I guess that saying is right "the happiest days are the day you buy your boat and the day you sell your boat!" Thanks everyone.
Parasympathetic
#22 Post by Parasympathetic » Fri May 14, 2010 7:06 am
Methinks it's the carb also, but all of the above should be checked anyway. In my old boat, the alcohol gas had left a concrete like substance coating all inside the carb and had clogged the jets so that it would only run under 3000 rpm.
If yours is not too far gone, this may save you a carb rebuild. You could try spraying some Seafoam into carb with high idle for about 5 minutes. Then spray very fast and heavy till the engine dies. Wait 5 minutes and then start engine again.
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
GregD
#23 Post by GregD » Fri May 14, 2010 8:58 am
BassFrequency
#24 Post by BassFrequency » Fri May 14, 2010 3:16 pm
take the plugs out, clean em off best you can, put them back, start the motor and rev it up. take the plugs out again and see if any appear darker or different than the others. good way to see if all your plugs are firing. sounds kinda like your lacking from one cylinder.
60HP Evinrude
Steveclv
#25 Post by Steveclv » Sat May 15, 2010 9:41 am
Take a timing light with you and check that the ignition advance system is working correctly.
It doesn't sound like carbs to me but ignition timing - carbs would cause a stutter or bad running - ignition timing plate being stuck would simply cause the engine to be down on power as it would not be getting enough advance - so your 60hp motor would only be producing say 35hp - so it would not be able to spin the prop which was set up for a 60hp.
Get the advance curve specs, remove the cover, connect the timing light to number 1 cylinder and start her up and check the timing at the engine speeds that the specs call for. If it's not advancing enough then your timing plate is stuck/corroded.
LTB Racing
#26 Post by LTB Racing » Sun May 16, 2010 7:35 am
This is a fuel issue (or lack of)w the carbs....if the motor is picking up RPM when you press in the key and dump fuel in through the enrichment valve then it is starving for fuel. ....and because you have to have fuel in the carbs in order to have fuel in the enrichment valve more than likely its not a fuel pump issue... Always start with your basics ie spark, fuel, compression but when a motor w/ these symptoms picks up RPM when u hit the enrichment circuit(choke) its usually a dead give away that its a fuel problem. 8)
LTB Racing
Quartershot T3-R Merc 2.5 260
Fiesta 18 Party Barge w/ Twin Evinrude 50's
http://WWW.LTBracing.com
"The great ones practice the basics"
Steveclv
#27 Post by Steveclv » Sun May 16, 2010 8:11 am
LTB Racing wrote:This is a fuel issue (or lack of)w the carbs....if the motor is picking up RPM when you press in the key and dump fuel in through the enrichment valve then it is starving for fuel. ....and because you have to have fuel in the carbs in order to have fuel in the enrichment valve more than likely its not a fuel pump issue... Always start with your basics ie spark, fuel, compression but when a motor w/ these symptoms picks up RPM when u hit the enrichment circuit(choke) its usually a dead give away that its a fuel problem. 8)
You are right, sorry I missed his second post with that information about the choke effect.
When you close the choke, it pushes a plate across the carb openings and this then increases the engine vacuum in the carb causing it to suck in a lot more fuel. This gives the fuel delivery system (fuel pump, hoses, tank pickup) an easier time so that any leak is 'masked' for a couple of seconds because the engine is sucking much harder.
Of course, choking the hot, running motor is going to cause it to stutter pretty quickly.
It could still be the diaphragm in the fuel pump that has a pinhole or as another poster suggested, a pinhole in the primer bulb or a leaking connector, or dirt in the needle valve or a bad carb gasket but I'm with you now that it's fuel related.
GreenGolfBall
#28 Post by GreenGolfBall » Mon May 17, 2010 9:31 am
yeah, we've already changed the fuel line, checked the fuel pick up from the tank, and rebuilt the fuel pump. It still runs the same, so I ordered 3 complete carb rebuild kits. Should be here this week. Lets keep our fingers crossed. I'll keep you guys posted. Thanks.
tkrein
#29 Post by tkrein » Mon May 17, 2010 10:10 am
do a compression check. since that is an easy one to rule out.
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
GreenGolfBall
#30 Post by GreenGolfBall » Mon May 17, 2010 1:16 pm
I'm 99% sure that compression is good. I accidently knocked one of the plug wires off once when I was putting the engine cover back on and boy it rode different!!! But i'll try it before we rebuild the carbs.
