Al the Mirthmaker (Mark III)
tuned
Re: Al the Mirthmaker (Mark III)
#196 Post by tuned » Mon Mar 17, 2014 5:55 am
So I had a mammoth work binge a couple of days ago. Unfortunately I was so busy that I forgot to take shots of my work. So I guess it didn't happen :biggrin2 Tell that to my aching and cramped muscles. It was cold going and I didn't want to slow down for anything. I sat in the 'bathtub' where the engine goes and final mounted the fuel pressure regulator, fuel filter, fuel relay , ecu, cdi, and a bunch of wire harnesses. These mostly mounted to the firewall in front of the motor. Zippy the Chimp would have fit in that hole better.
I wanted to move the boat while the ground was still frozen in order to avoid the spring mud, but needed to complete all those jobs first. It went surprisingly well, so we pushed forward and moved it. I prolly should have put a bigger door on my shed huh?
Still had an hour of daylight left although it had dropped to about 20 degrees. With the engine hanging on the hoist, I really wanted to get it set down somewhere for safety. Why not where it belongs? We pushed forward and dropped her in there.
Just in time too. The next night dropped to twenty below. About 4 inches of snow last night. So there it sits. Lots left to do, but a mammoth step forward. No late launches for me this year. Somebody else can have that stinkin' trophy :fyou
#197 Post by curtiscapk » Mon Mar 17, 2014 6:34 am
Nice work!!! :nana
Rascal
#198 Post by Rascal » Mon Mar 17, 2014 10:26 am
Congrats.... dude.
Rascal
Fishing Year Round SW Florida
Premier 22' 2012 Cast A Way
115 hp Honda, 15.5 x 13 prop
Sea Star Power Steering
Day Enclosure
Loan Star Anchor Winch
Fixed Mount ipad Air for
Rascal
#199 Post by Rascal » Mon Mar 17, 2014 10:27 am
Oops... duplicate post.
Rascal[/b]
Day Enclosure
fergusmj
#200 Post by fergusmj » Tue Mar 18, 2014 10:34 am
Nice work!
Ferg's Tritoon Build
pond tuuunes
#201 Post by pond tuuunes » Tue Mar 18, 2014 2:29 pm
Do you have a pic of engine bay without engine?
tuned
#202 Post by tuned » Tue Mar 18, 2014 5:22 pm
pond tuuunes wrote:Do you have a pic of engine bay without engine?
Sorry bro. I've been looking, without success. Know of any resources to bring a hard drive back from the dead? :cry:
pond tuuunes
#203 Post by pond tuuunes » Tue Mar 18, 2014 5:38 pm
sorry, no, I would loose alot also.
#204 Post by curtiscapk » Wed Mar 19, 2014 9:01 am
Todd,
I'll call you tomorrow. There is a chance you can still pull info off that drive.
tuned
#205 Post by tuned » Fri Mar 28, 2014 6:07 pm
curtiscapk wrote: Todd, There is a chance you can still pull info off that drive.
I have some small skills in this area. The drive is still running, data was corrupted and somehow my NTSF files got turned into RAW. There may be a software recovery available. Just too busy working and boat building.
Speaking of which, got the motor aligned and bolted down. It was nice to remove the hoist chain so I could build another of my world famous plastic tents.
The knot on top of my head says that it would have been nice to remove the hoist beam as well. Kind of low headroom (hands and knees) but at least I have a bit of heat again. Until then, it had been about twenty degrees. Now it is a comfy 50 degrees in my little tent with 20 degree metal
Finished 98% of fuel system. In-line fuel filter to left.
Fuel regulator. Things are getting TIGHT in the bathtub, but it is actually fitting!
Exhaust cutouts are IN and clamped! Woot. I still have to finish off the dump to free-air, but the worst is done. Somehow my planning actually worked. After measuring and guessing and guessing and measuring and calculating angles and heights and measuring some more, I had guestimated that I would clear the transom by 1" +/- 2". If it had been low, I would have been in deep trouble. Gonna clear by....an inch! How the heck did that happen?
ToonGuy
#206 Post by ToonGuy » Sat Mar 29, 2014 6:18 am
:dance
#207 Post by curtiscapk » Sat Mar 29, 2014 10:15 pm
Awesome! :nana :nana :nana :nana :nana
tuned
#208 Post by tuned » Tue Apr 08, 2014 11:54 pm
Back at it. Gotta hurry tho. The plow piles are down to 6 feet and I don't have much time.
So here's the latest:
Hooked up CDI and ECU and tidied up harnesses. The ECU is buried so deeply that I couldn't get a decent shot of it.
Did some dicey work on my swim platform. This series of shots is from underneath the platform looking straight up.
Had to cut out some of the 'webbed' bracing (AKA 1/4" aluminum flat strap). Tough going with limited space and unlimited tools. Grinder, sawsall, roto-zip. Thank god for my oscillating tool.
Then rebuild that bracing out of the way of the enormous hole that I accidentally drilled :shock:
The last shot will make sense out of it. Selectable exhaust is all done but a little control wiring!
Gonna hit it hard tomorrow too. Start cutting aluminum strut, braze it together with the Muggy-Weld and cover all that pretty work right back up.
#209 Post by curtiscapk » Wed Apr 09, 2014 5:55 am
Wahoo you go Todd! Getting close now! :alright
tuned
#210 Post by tuned » Thu Apr 10, 2014 12:45 am
Oh it is so on now.
Northwoods Engineering at its finest. Continuing in my tradition of 'tool-free teardown'.
Don't expect it to make much sense, but it will pretty soon. This counts as 'dry-boatin' doesn't it? :drink4
