georgiatoon
#31
Post
by georgiatoon » Thu Jan 13, 2011 2:32 pm
FloterBoter wrote:GregF wrote:The real issue is how well you protect the wood.
Bingo.
By coating the wood or sealing it, any defect however slight will excellerate decomposition of the wood not to mention the moisture already in the wood when you seal it. In a marine enviroment the wood must be able to dry. A little oxygen a little moisture and and almost sealed piece of wood equal rot. Not a pissin match just facts
91 ercoa clippper 19 foot
91 johnson 40 hp
GregF
#32
Post
by GregF » Thu Jan 13, 2011 2:39 pm
That might be true if this wood was totally open to the air but it is trapped between carpet and aluminum stringers. The edges will never really get dry if you use your boat very often and that is where the damage starts.
georgiatoon
#33
Post
by georgiatoon » Fri Jan 14, 2011 6:49 am
GregF wrote:That might be true if this wood was totally open to the air but it is trapped between carpet and aluminum stringers. The edges will never really get dry if you use your boat very often and that is where the damage starts.
In a proper installation the wood is insulated from the aluminum stringers as added protection but with CCA that is not a problem as there are no reactive metals in CCA treated plywood. Can you name even one pontoon builder that glasses or seals there deck? I can't find
ne. I do however agree with you on sealing the edges.
91 johnson 40 hp
FloterBoter
#34
Post
by FloterBoter » Sat Jan 15, 2011 1:35 am
omg, are you saying we may see...
CATASTROPHIC FAILURE?!??!?
georgiatoon
#35
Post
by georgiatoon » Sat Jan 15, 2011 4:34 am
FloterBoter wrote:omg, are you saying we may see...
NO - THE EFFECTS OF GLOBAL WARMING ON PLYWOOD DECK FAILURE
91 johnson 40 hp
Post
by lakerunner » Tue Jan 18, 2011 12:47 pm
We are so lucky to have a fucking expert in plywood and corrosion
GregF
#38
Post
by GregF » Tue Jan 18, 2011 1:49 pm
It appears we have two
One who thinks rot and corrosion happens and one who denies it.
#39
Post
by badmoonrising » Tue Jan 18, 2011 2:12 pm
Nope your reading comprehension skills are seriously lacking. You said your corrosion was caused by stainless hardware. I have a 43 year old aluminum boat that says different.
Post
by lakerunner » Tue Jan 18, 2011 2:17 pm
I love it when a plan comes together, HAHAHAHAHAHAHAHA
GregF
#41
Post
by GregF » Tue Jan 18, 2011 2:36 pm
Maybe when Ron has a reason to remove some bolts from his boat we will get an independent view and an apples to apples comparison.
#42
Post
by badmoonrising » Tue Jan 18, 2011 4:45 pm
lakerunner wrote:I love it when a plan comes together, HAHAHAHAHAHAHAHA
Just wondering if anyone else's boat has any stainless hardware. I was thinking of a class action suit against Tracker since they installed faulty hardware on it that causes severe corrosion.
I was thinking maybe the Cochran firm. They still use Johnny's picture so they MUST be good, right ?
#43
Post
by badmoonrising » Tue Jan 18, 2011 4:46 pm
GregF wrote:Maybe when Ron has a reason to remove some bolts from his boat we will get an independent view and an apples to apples comparison.
badmoonrising wrote: I have a 43 year old aluminum boat that says different.
georgiatoon
#44
Post
by georgiatoon » Wed Jan 19, 2011 9:09 am
badmoonrising wrote:lakerunner wrote:I love it when a plan comes together, HAHAHAHAHAHAHAHA
I don't think we will win, I can't find a problem on my 20 year old toon
91 johnson 40 hp
