NOT AGAIN!!!
The_Hellbilly
NOT AGAIN!!!
#1 Post by The_Hellbilly » Wed Sep 21, 2011 6:01 am
:x :x :x
2005 Voyager 22ft Tritoon
2004 Honda 135hp
playcat
Re: NOT AGAIN!!!
#2 Post by playcat » Wed Sep 21, 2011 8:28 am
Is that a shadow from the camera flash, or is there a crack all al around that drain plug?
playcat
JC 266 TriToon
Kerr Reservoir, VA
The_Hellbilly
Re: NOT AGAIN!!!
#3 Post by The_Hellbilly » Wed Sep 21, 2011 10:40 am
playcat wrote:Is that a shadow from the camera flash, or is there a crack all al around that drain plug?
Sorry bout that, bad pic angle
2004 Honda 135hp
hyper
Re: NOT AGAIN!!!
#4 Post by hyper » Wed Sep 21, 2011 11:35 am
does you logs have a warranty? I know smokercraft has lifetime and you should have something like that I would believe. If it does take it to them
2003 50HP Elpto 2 stroke
mike
Site Owner
Re: NOT AGAIN!!!
#5 Post by mike » Wed Sep 21, 2011 11:36 am
bummer dude
The_Hellbilly
Re: NOT AGAIN!!!
#6 Post by The_Hellbilly » Wed Sep 21, 2011 12:22 pm
hyper wrote:does you logs have a warranty? I know smokercraft has lifetime and you should have something like that I would believe. If it does take it to them
Lifetime warranty so no worries about getting it fixed. The same log had a leak last year that I had fixed. When I get a chance, I will attempt to find the leak myself. It is a fairly simple process. I will make a tutorial with a lot of pics if/when I find it.
2004 Honda 135hp
Ron Burgundy
Re: NOT AGAIN!!!
#7 Post by Ron Burgundy » Wed Sep 21, 2011 2:24 pm
Was it a cracked weld last time?
The_Hellbilly
Re: NOT AGAIN!!!
#8 Post by The_Hellbilly » Wed Sep 21, 2011 3:17 pm
Ron Burgundy wrote:Was it a cracked weld last time?
Yes, along one of the strakes. I'd look up a link to the thread if I wasn't on my blackberry
2004 Honda 135hp
Ron Burgundy
Re: NOT AGAIN!!!
#9 Post by Ron Burgundy » Wed Sep 21, 2011 5:45 pm
That sucks. I had water in one of my 'toons before, but it was because of salt water corrosion. Either way it's no fun. Now I am always checking to see if I am listing.
Ron Burgundy
Re: NOT AGAIN!!!
#10 Post by Ron Burgundy » Wed Sep 21, 2011 5:49 pm
I found the thread. That was the infamous SS thread :happy
GregF
Re: NOT AGAIN!!!
#11 Post by GregF » Wed Sep 21, 2011 6:18 pm
Did you check for galvanic corrosion? :)
spurhunter
Re: NOT AGAIN!!!
#12 Post by spurhunter » Wed Sep 21, 2011 6:23 pm
Ive givin up on thinking you can keep water out of them, I drain every 2nd trip to the lake. Oh well.... :cry:
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
Oldboater
Re: NOT AGAIN!!!
#13 Post by Oldboater » Wed Sep 21, 2011 8:05 pm
I had a cracked weld in my two year old Starcraft, fixed under warrenty. When you use a lift it is easy to see water draining from pontoon!
90 HP Yamaha 4 Stroke
Ocean City, Maryland
GregF
Re: NOT AGAIN!!!
#14 Post by GregF » Thu Sep 22, 2011 12:14 am
I got about a gallon out of each pontoon the other day, accumulated over about a year. They seemed to be holding air pressure (air came out when I pulled the plug) so I am not sure where the water comes from.
hyper
Re: NOT AGAIN!!!
#15 Post by hyper » Thu Sep 22, 2011 5:24 am
I have so far never had any water in my pontoon's, boat is 8 years old and I use it alot. I checked it and they are dry as a bone. I really hope I dont have to deal with this. It sucks for you to have to take the time to find it and take it to have it repaired. Hope it works out good and I look foward to seeing the results.
thanks
Jeff
