Would this be a good backup battery?
Mosnowman
#1 Post by Mosnowman » Fri Jun 22, 2012 3:39 pm
Newb question....I have a Merc Verado 150 and being an old Boy Scout want to be prepared and have a back up battery for starting purposes if needed?
Is this an adequate starting marine battery or that purpose?
Exide XMC-31 MEGACYCLE AGM-200 Sealed Maintenance Free (AGM) Marine Battery
BUSY LIVING...
Columbia Mo BZLIVN
Re: Would this be a good backup battery?
#2 Post by Bamaman » Fri Jun 22, 2012 6:35 pm
Hey, I'm an Eagle Scout. The Boy Scout motto is "Be Prepared." I don't think it meant to "be prepared" to spend a bunch of money for something you might not need.
Is anything wrong with your main battery?
I'm prepared. I carry a cell phone with my neighbors' phone numbers programmed in it so they can come and tow me back to my boathouse if I have a problem.
All kidding aside, if you're not running a trolling motor or a big sound system, I don't see any reason to run a deep cycle battery. They're not cheap, and don't seem to last as long as a regular car battery. And even with twin batteries, they'd need to be the same type of battery.
Mosnowman
#3 Post by Mosnowman » Sat Jun 23, 2012 10:07 am
Bamaman...thanks for saving me some dollars! :happy
Being a total Newb I didn't know if guys carry one or not....I don't have a trolling motor so it sounds like relax and don't worry! I'm not quite to the "chilling" stage yet but getting there with this new boat... :scared
BUSY LIVING...
Columbia Mo BZLIVN
#4 Post by Bryden24shp » Sat Jun 23, 2012 11:22 am
Mosnowman wrote:Newb question....I have a Merc Verado 150 and being an old Boy Scout want to be prepared and have a back up battery for starting purposes if needed?
If you do not have Verado Power steering assist, yes you are fine. If you have it. Go with the AGM....
Here is what the Verado Owners Club states, From Mercury...
"If you have a 6 cyl Verado, you have power steering. It is optional on the 4 cyl units. It
takes a HUGE amount of power to run and is the reason we recommend at least 1100
MCA AGM type batteries. And be careful how you use it. If you hold the wheel against
the “stop” when docking, you can use up to 60 amps while the pump binds. Just use it
near the stop, no need to hold it there. By the way, power steering is the first thing to
go out if you batteries are weak. Our experience is anything less than about 12.4
volts and you might have problems."
And they are expensive, $200.00 to 250.00 each, so around $500.00 for a dual battery set up. Hope this helps!
Bryan
#5 Post by Bamaman » Sat Jun 23, 2012 12:45 pm
He's right about Mercury power steering requiring two batteries--if you happen to have it on your boat. And AGM batteries are different from lead type batteries, and much more expensive.
Merc. power steering is really a really power sucker. Someone mentioned they were considering soundproofing where the pump is, and that their boat is very loud between the pump and the Verado's supercharger.
I don't know about the SeaStar power steering's electrical requirements.
Mr Geets
#6 Post by Mr Geets » Sat Jun 23, 2012 4:28 pm
I have an extra battery loose (secured for safe travel) in the back of my truck - just in case. In worst case scenarios, we have taken a battery out of a vehicle. Some good 20 foot booster cables are handy at any time. Have fun!
I live in my own mind
Ain't nothin but a good time
No rain just the sunshine
Out here in my own mind
-Lyle Lovett "In My Own Mind"
2011 Princecraft 21 full camper top
90 Merc efi 4 stroke
Rocky1965
#7 Post by Rocky1965 » Wed Jun 27, 2012 8:53 am
I carry a portable jump starter/air compressor, but was wondering how to set up two batterries with a switch to select battery 1-2, any ideas?
Rocky
2012 Sun Tracker Part Barge 18 DLX
Mercury 60 HP 4 stroke BigFoot
#8 Post by curtiscapk » Wed Jun 27, 2012 9:15 am
Rocky1965 wrote:I carry a portable jump starter/air compressor, but was wondering how to set up two batterries with a switch to select battery 1-2, any ideas?
search is your friend
viewtopic.php?f=2&t=12425&p=96503&hilit=battery#p96503
#9 Post by dockholiday » Wed Jun 27, 2012 9:55 am
He is the perko which I have, but there are other manufacturers
www.perko.com/catalog/category/battery_switches/
Rocky1965
#10 Post by Rocky1965 » Wed Jun 27, 2012 10:52 am
Thanks for the ideas, I will research some of the switches and see which is best for my application. :thumbsup
Rocky
Oldboater
#11 Post by Oldboater » Wed Jun 27, 2012 4:27 pm
AGM batteries don't like to be deeply discharged, it shortens their life. I would recommend a battery maintainer if you only periodically use your boat (3-5 days between use).
In fact a battery maintainer is a good idea for any periodically used battery, it will greatly extend life.
90 HP Yamaha 4 Stroke
Ocean City, Maryland
Rocky1965
#12 Post by Rocky1965 » Thu Jun 28, 2012 8:33 am
I do have a maintainer, was just wondering about a back up battery, just in case I play the radio too long between runs. Thanks
Rocky
woolznaz
#13 Post by woolznaz » Thu Jun 28, 2012 11:38 am
For less than $50 you can buy a very lightweight, portable, rechargeable jump starter. It is cheap peace of mind knowing it will be enough to start your boat if your battery craps out. Charge it up once every 90 days or so, and you'll never worry about a dead battery stranding you after a long day of coving out.
2007 South Bay 925 Tri-toon
5.7 Volvo I/O
lakebilly
#14 Post by lakebilly » Thu Jun 28, 2012 1:57 pm
If you own a Verado, I would highly recommend a dual set of AGM batteries. I found out the hard way how voltage dependant these motors are. I lost my entire memorial day weekend because I was too stuborn too replace my batteries. They had enough juice to crank the engine, but the PCM would not allow the injectors or plugs to fire. I'm a paying member of the Verado Owners Club and they immediatley told me what my problem was, but I didn't listen. It wasn't until about 2:00PM Memorial Day that I went to Sears and dropped $575.00 on two new Die Hard Platinums. It fired right up once the new batteries were installed. Damn, did I feel stupid. But now, I've got plenty of peace of mind.
-Lakebilly
Tri-Lakes, Indiana
'07 Harris Royal Heritage
Mercury Verado 175
