Prop Recommendation for New Toon
homey
#1 Post by homey » Sat Jul 07, 2012 9:05 am
While breaking in this engine I am finally to the point where I can run it at WOT for small periods in time. I am only getting 5000 RPM. According to Mercury I should be hitting 5700 RPM's. The boat had an almost full (20 plus gallons) tank of fuel. Also I figured we had around 1000 LBS worth of passengers. I will be buying an extra prop soon and was curious if I should consider going to a different pitch and/or a 4 blade prop and use the OEM prop as a spare?
2011 Harris Floteboat CX 200 Cruiser
2002 Yamaha 800XLT
BoatCop
Re: Prop Recommendation for New Toon
#2 Post by BoatCop » Sat Jul 07, 2012 9:08 am
What size engine do you have, and what is the current prop size? That would give us a baseline to figure out where to go from there.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
homey
#3 Post by homey » Sat Jul 07, 2012 9:27 am
It is a 50Hp Mercury Big Foot with a 14x11P prop.
2002 Yamaha 800XLT
cvslawrence
#4 Post by cvslawrence » Sat Jul 07, 2012 10:16 am
You need to test your setup with a light load, 1 or 2 people, 1/2 tank of fuel, one cooler full of test beer...
I think you will be pretty close to max rpm with the test set up, and as you add load to the boat your rpm and speed will drop.
Now, if you plan to use the boat loaded most of the time, a second prop would be a good idea, going down to a 9 pitch would be a good start.
Then you can use a different prop for light load[original] and the lower pitch for loaded boat.
homey
#5 Post by homey » Sat Jul 07, 2012 10:25 am
Thank You! Will try that setup shortly and will advise!
2002 Yamaha 800XLT
BoatCop
#6 Post by BoatCop » Sat Jul 07, 2012 10:51 am
You've got 2,000 lbs (dry weight) with just 50 hp. Figure 120 lbs for a tank of gas. 30 lbs, ice chest. 1,000 lbs passengers. Around 3,150 lbs total. That's a lot of weight for a (relatively) low hp engine. You might be propped right, just pushing that little 50 to its limit.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
Doctordeere
#7 Post by Doctordeere » Sat Jul 07, 2012 3:59 pm
I've got the same motor on a 20 foot two-tube Bentley that currently has a 14x9. I can easily wrap it up to 6200+. That's with approx. 450# in people, 140# in fuel, and around 75# of gear and coolers. Will be switching to a 14x11 as soon as I get a chance. The 14x11 is what both the Mercury prop selector and the Turning Point prop selector say should be on my rig (14x11 for approx 5800 RPM WOT).
2012 Encore Bentley 200 Cruise SE
50HP Merc EFI 4stroke Bigfoot
Lake Allatoona - Glade Marina
Heavily Medicated For Your Protection
Doctordeere
#8 Post by Doctordeere » Sat Jul 07, 2012 4:07 pm
cvslawrence wrote:You need to test your setup with a light load, 1 or 2 people, 1/2 tank of fuel, one cooler full of test beer...
^^ That's a critical um... tool right there, every bit as important as a 1 1/16 prop nut wrench. ^^
rancherlee
#9 Post by rancherlee » Sun Jul 08, 2012 5:41 am
5000rpm with a good size load on really isn't too bad, You might look into a 14x9 4 blade for those heavy load days, should act like a 14x10 3 blade would have which will add ~300-400rpm.
