Electric Anchor Winch
BartMan
#1 Post by BartMan » Mon Jul 09, 2012 10:57 am
I recently purchased an electric anchor winch: http://www.overtons.com/modperl/product ... rchID=4006
I have installed it on the bow, but the wires for the unit are too short to directly tie to one of my two batteries in the back. Which is the best option?
1. I can get the wires to the helm, then attach to one of the existing lines going back to the battery.
2. Install protable 12V rechargeable under helm just for the winch.
3. Splice a line long enough to reach the batteries (would be in helm compartment) with silicone wire nuts.
Any other options better?
Thanks, Bart
Bart
2012 Bentley 240 SE Cruise
115 HP Merc 4-stroke EFI
DeBary, FL - St. Johns River & Lake Monroe
USAF '79 - '88
BobG
Re: Electric Anchor Winch
#2 Post by BobG » Mon Jul 09, 2012 11:12 am
BartMan wrote:Any other options better?
Thanks, Bart
Well, maybe use a wire stretcher, or a boat squisher? :rofl
#3 Post by curtiscapk » Mon Jul 09, 2012 12:29 pm
Splice em. :2cents
ronb
#4 Post by ronb » Mon Jul 09, 2012 12:41 pm
From battery to winch...
1. Fuse rated for winch
2. Heavy gauge wire (dependent on amperage draw expected for device) up to a
3. A relay (also rated for winch) under the helm.
4. Use the main power switch if you have one to activate the relay
5. Power out from relay to winch.
Even if you decide not to use a relay, which you might not want because it is extra parts, I would still recommend a fuse at the battery and then splicing it to use a single long run between the winch and the battery box. I would not tie into the existing main power feed because I would be concerned that it was sized appropriately for the built in electrical system and might start popping fuses if there is too much amperage draw. But using it to trigger the relay would be very minimal.
Reason to use the relay
Cut off all power to the boat from a single location (or 2 locations on my pontoon, the battery switch and the main power toggle on the helm)
Reason NOT to use a relay
You might need to drop or pull anchor quickly and you don't want to fuss with looking for and remembering to switch the main switch.
Or, you could mount the winch on the rear next to the batteries...
-ron
2007 South Bay 922CR
Mercury 90hp Optimax
Fargo, ND
