Drum Brake?
captainjack
Drum Brake?
#1 Post by captainjack » Mon Jul 30, 2012 8:05 am
I had my breaks redone this spring well when changing another tire yesterday one is dragging. Its an hour away from where I had it fixed can I take some pressure off is this easy to do an how? Thanks for any tips!
2008 Playcraft Extreme 2600
2008 300 Mercury Verado
2008 Bear Trailer
Iowa
jimrs
Re: Drum Brake?
#2 Post by jimrs » Mon Jul 30, 2012 12:40 pm
You can open the bleed valve on the dragging wheel and relieve some pressure. I hate drum brakes they are a lot of trouble and work.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
captainjack
Re: Drum Brake?
#3 Post by captainjack » Mon Jul 30, 2012 12:54 pm
Tried that first wasn't any help.
2008 Bear Trailer
Iowa
cvslawrence
Re: Drum Brake?
#4 Post by cvslawrence » Thu Aug 02, 2012 7:31 am
There should be an adjuster in there, look for an oblong plug on the backing plate.
Should be a star wheel adjuster in there, use a flat tip screwdriver to adjust it, if you can jack that wheel off the ground, back the adjuster off until the wheel turns by hand with a slight drag from the shoes.
Hope this helps!
