As my wife says, " you aint shot in the ass with brains, are ya?" Well, search didnt get me my answer, so sorry to post an age old question. I bought some muriatic acid and am getting anywhere from 50/50 to 30 to 1 dilution ratio. I have used raw aluminum acids in the past and like the results.
I would like opinions on dilution ratios. I just have waterline and dirt/dark streaks on the sides of the toons from the rail screws,nothing major.
Thanks for any consructive advice. And I do plan to use the acid, and wont be polishing. I gave that up with the Harley,,,
Another muriatic acid question,,
- lounge lizard
99 Voyager 21' fish n cruise /Merc 115
Duramax/Lance 835
KTM/Honda/Polaris
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
Duramax/Lance 835
KTM/Honda/Polaris
Re: Another muriatic acid question,,
Yeah, somewhere in there ought to work!lounge lizard wrote:getting anywhere from 50/50 to 30 to 1 dilution ratio
HCL is tough on aluminum. I would start with a little splash in a gallon of water. You can always add more acid.
I would have to agree with GregF HLC is too strong I've used Alumiprep 33 for years on aluminum with no problems put a little on some scotch bright scrub a little and rinse with water.GregF wrote:HCL is tough on aluminum. I would start with a little splash in a gallon of water. You can always add more acid.
http://chemical-supermarket.com/Alumipr ... tgodOWAAvw
WILD MAN
2008 SOUTHBAY 822CR SUZUKI DF70
2011 BASS TRACKER 175 TF MERCURY 60
East Mississippi
East Mississippi
- lounge lizard
Well, once again the neighbors had a comedy session. The acid didnt work too bad, but the plunger kept melting on my spray bottle. Went thru 3 of them. The sizzle is a bit unnerving also.
So,, screw that, Im going to the shop for something a bit "better" . I ran out of spray bottles and still have 1/2 a toon to clean.
Duramax/Lance 835
KTM/Honda/Polaris
Duramax/Lance 835
KTM/Honda/Polaris
The best thing is a real acid sprayer. They have them at Home Depot. I needed one to acid stain my driveway.
