Is this a bad idea for cleaning carpet?
Mosnowman
#1 Post by Mosnowman » Sun Aug 05, 2012 3:56 pm
So as the season is unfortunately growing shorter I started thinking about seasonal cleaning...specifically my carpet. My boat is less than 6 months old so carpet is pretty new but I have a few stains on the carpet. I was thinking since this carpet is "marine grade" could I take it to the local car wash and powerwash it with car wash soap and then rinse it real well? Or should I stick to treating it like indoor carpet cleaning? I'm lazy thus my question.....thanks! :donno
BUSY LIVING...
Columbia Mo BZLIVN
plane jim
Re: Is this a bad idea for cleaning carpet?
#2 Post by plane jim » Sun Aug 05, 2012 4:06 pm
I have a small electric washer at home that does a nice job-I do not know about your coin operated car washes but here around Houston they recycle the water and it smells bad. I guess that happens when you see someone washing the horse trailer out in the car wash!!!!!!!!!!!!!!
Redneck_Randy
#3 Post by Redneck_Randy » Sun Aug 05, 2012 4:09 pm
With our old pontoon I would just drop the trailer tongue on the ground and use a soft bristle brush and scrub the carpet down and rinse with the water hose. Then I used a window squeegee to get the rest of the remaining water out of the carpet. Worked very well.
With the new boat, I bought Bissell Little Green and use it now.
_______________________
2011 Silver Wave Play 230
Honda BF150
2013 4X4 Silverado
gramps
#4 Post by gramps » Sun Aug 05, 2012 4:23 pm
I would just treat the spots that need cleaning, why clean the whole thing if it doesn't need it.
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
Badger
#5 Post by Badger » Sun Aug 05, 2012 5:37 pm
The boat I recently bought had been used and abused by some raccoons. The carpet was spot treated in the worst areas then all of the carpeting was cleaned with a Rug Doctor and very hot water. It looks like new again.
Heatman
#6 Post by Heatman » Sun Aug 05, 2012 7:08 pm
Just use the powerwasher. I always have. Mine is gas, 2800 psi, use it a few times a year for 8 years with no problems. No soap is really needed. Just be careful around the seats.
Sheridan, Indiana
#7 Post by dockholiday » Sun Aug 05, 2012 9:23 pm
Yep the psi at the car washes typically don't have the psi to do a real good job. Think I would rent a pressure washer for the day that way you might be able to do so other stuff around the house with it. I saw a 2800psi at Sams today for a little over 2 hundred dollars. The prices for those thing have come down alot since I purchased mine.
Oh, northern tool also has some good prices along with a pretty good selection
ronb
#8 Post by ronb » Mon Aug 06, 2012 8:40 am
Just last weekend I did exactly what you are asking about. It worked great and cost me only $6.
I spot treated the carpet bad spots, then used the high pressure wash to completely soak the entire carpet. Then using a spare bucket (visible in one of the pictures) I washed pontoon and trailer while the carpet soaked. After everything was lathered up I plunked in some more $$ and high pressure rinsed everything. The carpet turned out great (I wish I had before and after pictures, I can get some 'after' tonight)
The biggest issue I had was physically fitting the pontoon through the wash bay. With an 9' door and a 8'6" wide pontoon you really don't get a whole lot of wiggle room, and it should go without saying that the 'pucker factor' was very high, and on several occassions I though to myself "WFT have I just done, how am I going to get this all the way through and out without denting/damaging something" Luckily I did make it all the way through, but if you attempt to do this try and find a wash with an outdoor bay, or at least very wide berth leading up to the door and on the way out. And try to avoid obstacles...
And to negotiate the final turn I had to turn as sharp as I could, then I almost hit a huge boulder, then I had to back up ever so slightly and crank it hard again, thank god I was able to negotiate this turn. the driver side trailer tires almost pivoted right where they sat by the edge of that concreted in-place vacuum.. not fun.
-ron
2007 South Bay 922CR
Mercury 90hp Optimax
Fargo, ND
BobG
#9 Post by BobG » Mon Aug 06, 2012 9:11 am
Sure glad we know of a few car washes with outside bays! That looks TRICKY!
oldmn19
#10 Post by oldmn19 » Mon Aug 06, 2012 3:19 pm
I have a Karcher electric 1200 PSI pressure washer i got at Lowes 5 years ago for around $100.00, use it around the house and on the boat. does a good job on carpet, toons to get scum off, have been very happy with it, just be careful if you buy a pressure washer, your tempted to get a higher pressure unit, but you can really damage things with them. It works good to get the scum off the motor too. :2cents I buy Orange cleaner at the Dollar Store, spray the spots good let set 15 minuites or so them pressure wash till I get no more suds, carpet still looks good after 6 years.
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
