Pumps For Inflatables
Drago
#1 Post by Drago » Tue Aug 21, 2012 3:39 pm
Has anyone here ever considered using or have experience with the types of pumps designed for inflatable boats and kayaks?
http://inflatableboats.com/index.php?ma ... Path=14_28
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
serpa4
Re: Pumps For Inflatables
#2 Post by serpa4 » Tue Aug 21, 2012 4:11 pm
Not specifically. I use a 12v one for tubes that is rated at 3psi. That is the reccomended pressure for most tubes.
1roadking
#3 Post by 1roadking » Wed Aug 22, 2012 5:57 am
I use a 12volt pump designed for tubes and it works great!
150 yamaha 4 stroke
2012 tundra tow rig
The_Hellbilly
#4 Post by The_Hellbilly » Wed Aug 22, 2012 7:57 am
In my experience a 12v DC pump won't get the tube full enough to prevent it from submerging on some tubes. I picked up an Airhead pump from Walmart to fully inflate the tubes. It usually takes just a few pumps to do the job.
airhead pump.JPG (42.36 KiB) Viewed 2802 times
2005 Voyager 22ft Tritoon
2004 Honda 135hp
rbiederwolf
#5 Post by rbiederwolf » Wed Aug 22, 2012 10:18 am
I have a Kwik Tek Airhead High Pressure Air Pump (12-Volt). Hooks up to battery connections. Had it for about a year now . Works great. Blows up a large 3 person inflateable in about 5 mins. Has plenty of power to fill tube up completely. I do not believe that the cigarette lighter version will supply enough power.
http://www.amazon.com/Kwik-Tek-Airhead- ... k+air+pump
2008 Yamaha 150hp
mike
Site Owner
#6 Post by mike » Wed Aug 22, 2012 12:42 pm
I use that foot operated bravo 2, it works VERY well and is fast!
GregF
#7 Post by GregF » Wed Aug 22, 2012 12:57 pm
I am surprised that some enterprising guy is not setting up a real compressor/air pump at the ramps and blowing up tubes for a couple bucks each. It might be another thing a marina could do.
I end up blowing up tubes for my neighbors with shop air here, just as something neighbors do for neighbors.
It is hard to beat a real 120v or 240v air pump if you have access to power.
#8 Post by dockholiday » Wed Aug 22, 2012 12:57 pm
Got one of these years ago and they work well. The magic air can also be use to deflate. They also make a 120 to run on household current.
http://www.campmor.com/metro-magic-air- ... pump.shtml
GregF
#9 Post by GregF » Wed Aug 22, 2012 1:02 pm
They make a bigger model that approaches a real horsepower (in spite of the 4HP claim)
http://www.amazon.com/Metro-Vacuum-DIDA ... =qrb-su-20
GregF
#10 Post by GregF » Wed Aug 22, 2012 1:09 pm
If you have access to 120v you could just bring your shop vac head (you don't need the can). It would even be worth getting one in a garage sale cheap and stripping it down.
screwball
#11 Post by screwball » Wed Aug 22, 2012 1:47 pm
We have 2 Colman 12v high volume pumps on board. Really do the trick.
We are really Steve and Vesta Brown
2012 Sun Tracker 18' Party Barge w/ 75hp Merc.
A pair of 2011 Seadoo GTI-SE PWC's
2 Harley Davidson Tri-Glides '09 mine, '11 hers
[s]A couple of Polaris 500 Scrambler Quads[/s]
We take our recreation VERY seriously
#12 Post by dockholiday » Wed Aug 22, 2012 7:23 pm
Got one of these for the car. I am sure it would not do as good as the high volume pumps, but should do the job, and you would have one for the car also
http://www.amazon.com/Goodyear-i7000-12 ... lime++pump
Oh forgot to say they make a high volume pump the expels air on both the up and down strokes.
Drago
#13 Post by Drago » Thu Aug 23, 2012 4:42 am
Thanks for the feedback. We normally blow up the tubes (Big Mable and a Donut off brand) with the wet vac at home before leaving. We have two of the 12VDC cheapo pumps from SportsStuff and WalMart and two of the two way hand pumps on board to fill stuff while on the water. We have plenty of high amperage cig lighter plugs wired for heavy duty use during the day. I'm just doing some snooping around looking for something more potent to travel with that can be used on the boat. Looks like some of those in the link I sent pull some monster current. I'll most likely spring for that Bravo 2 Foot Pump first. It looks like it has high volume and enough pressure to top off the big tubes. Another big plus is that anyone can use it.
Kenneth & Joy
Lake Conroe, Texas
2006 Yamaha F225
