Thank you!
LVjayhawk15
Thank you!
#1 Post by LVjayhawk15 » Sun Sep 02, 2012 7:30 pm
This is a semi-loaded 'thanks'.
But really, THANK YOU TO ALL! I hope I didn't wear any of you out with questions and what not, but this site is great and all of YOU helped me and my wife go to 'pontoon school' and make purchasing one go easily!
So yes, we finally bought one!!! Its an 05 Sundance Majestic Legend, 26ft and an upper deck with a 140hp motor.
(photo attached)
BUuuuttt....i do need some 'outboard' school lessons. The only watercraft we have is the waverunner, so the outboard motor is new to me. I've read up on winterizing, changing lower oil, plugs, etc. I even found a random youtube clip on changing the fuel filters (how often to do that?) Anything else? Im mechanically inclined, just need to know 'what' to do and ill do it.
Also, once im done for the day and I pull the boat back out of the water, what is next? Like on the waverunner, we have drain plugs to pull, etc. Is there anything like that? Drain water out of the motor? (im assuming they're water cooled so there would be some to drain after use?) Also, I usually flush the waverunner each outing, is the necessary for an outboard?
Like I said, it was a 'thanks' with more questions attached!
But SERIOUSLY, thank you :thumbsup all and I look forward to sharing more photos and stories with you all!
-Corrie & Jenn
side view.jpg (93.26 KiB) Viewed 3277 times
"I bust mine so I can kick yours"
--Corrie--
gramps
Re: Thank you!
#2 Post by gramps » Sun Sep 02, 2012 7:48 pm
LV nice boat, it looks real clean. Outboards are self bailing and there isn't anything to do to it after you use it, especially in warm climate.
I would contact the mfg of motor and get an owners manual and it will tell you everything you should know or look on ebay.
Try to use gas with no ethonol, if the eng is a 2 stroke use good oil. Have fun.
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
Re: Thank you!
#3 Post by ROLAND » Mon Sep 03, 2012 12:03 am
Corrie... congratulations on the new toon... from the pic she looks to be a very clean boat.... very nice.... You asked about flushing the outboard... If you were using it in salt water I would say flush it after every outing if possible, but on inland lakes, it's not crucial. Having said that, I usually hook the garden hose up to my yamaha and fun clean water thru it about once a month or so... or you can do the same thing with a set of muffs.... just make sure if you're using muffs to run the motor.... if you're flushing with the garden hose, you do not need to run the motor...as for winterizing.. I live in the deep south and my boat is stored indoors in a well insulated ( but not heated ) building... I've had it for 2 years and I have not winterized... I would suggest that if you don't drain your fuel out of your tank at the end of the season, be sure to use a stabilizer on the fuel left in the tank... again, enjoy that new toon...
jimrs
Re: Thank you!
#4 Post by jimrs » Mon Sep 03, 2012 6:38 am
That's why we buy toons. Very little maint on them other than cleaning and treating the seats. Looks like you got what you were looking for. Post some more pictures of it showing the insides and up a bit closer. Looks real good.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
GregF
Re: Thank you!
#5 Post by GregF » Mon Sep 03, 2012 9:58 am
Lose that furniture and it becomes pretty much maintenance free ;)
Keep fresh oil in the motor (up and down) and you are good to go.
Re: Thank you!
#6 Post by dockholiday » Mon Sep 03, 2012 10:05 am
Can't tell how much vinyl you got but get it clean as you can an apply several coats of 303. you can pick it up online, an the gal is cheaper per oz.
LVjayhawk15
Re: Thank you!
#7 Post by LVjayhawk15 » Mon Sep 03, 2012 12:06 pm
Up and Down? As in the lower unit oil?
--Corrie--
Ron Burgundy
Re: Thank you!
#8 Post by Ron Burgundy » Mon Sep 03, 2012 12:29 pm
I always flush my motor after use, but I am in saltwater. Still not a bad idea if you run in dirty water or think you may have got some sand in the intake.
GregF
Re: Thank you!
#9 Post by GregF » Mon Sep 03, 2012 4:32 pm
Yep, just run the 100 hour check list but that is the big one. Change all the the oil and hit the lube points. Other than that it is just a good look over.
LVjayhawk15
Re: Thank you!
#10 Post by LVjayhawk15 » Mon Sep 03, 2012 6:04 pm
Is there a link to one of those?
--Corrie--
GregF
Re: Thank you!
#11 Post by GregF » Mon Sep 03, 2012 7:29 pm
The various maintenance check lists are usually in your owner's manual and they are in the shop manual.
This is the Yamaha F70 book
http://www.yamaha-motor.com/assets/serv ... 2_1808.pdf
LVjayhawk15
Re: Thank you!
#12 Post by LVjayhawk15 » Mon Sep 03, 2012 7:32 pm
cool. Owners manual being found right now!
--Corrie--
LVjayhawk15
Re: Thank you!
#13 Post by LVjayhawk15 » Tue Sep 04, 2012 8:13 pm
More pics wanted, so more pics delivered!
back seats.jpg (56.25 KiB) Viewed 2737 times
front seats.jpg (54.33 KiB) Viewed 2737 times
--Corrie--
Kalop
Re: Thank you!
#14 Post by Kalop » Tue Sep 04, 2012 8:20 pm
Nice boat !!! Congrats !!
Looking to buy Pontoon (Tritoon hopefully)
2000 Sea Doo Challenger 1800 Jet Boat (sold July 2012)
1995 Sea Doo XP Jet Ski
2005 Joyner Sand Spider 650cc buggy
DFW Texas area
Re: Thank you!
#15 Post by curtiscapk » Wed Sep 05, 2012 6:07 am
nice LV! did that come from Kansas? It looks familiar? :donno
