Eliptical pontoons vs round pontoons!
Is there a major difference in ride, efficiency, and speed between a boat that has 27" pontoons and one that has 32" eliptical pontoons?
Just Laxin
Re: Eliptical pontoons vs round pontoons!
I have read in the past about tests between the two and they have said that round toons are more efficient and faster. How much the difference really is I don't recall.
2012 South Bay 522 SL TT
Merc. 150 EFI Four Stroke
Depends on the application, almost all the manufactures add strakes to the round tubes for lift. That tube, is no longer round. Manitou uses 3 rounds with reversed strakes. Now that tube is v shaped. Thats how they get speed from them. Most are round with a ^ welded to them, for lift. Not round no more. I've been thinking about removing my ^ strake and welding it on its side, for more more of a V shaped pontoon, on the Premier. And lowering the center pontoon 4 inches. To make it more of a V hull design. May be another winter project added to the list.
I think the deal with the ellipticals (with strakes) is that they're much more buoyant--and capable of loads approaching that of tritoons. They're fast, but just don't handle as well as some of the tri toons.
My new Bennington has the 3/4 tritoon with strakes, and it appears the same boat with ellipticals will run 2 mph higher. I'm satisfied with my hull--for my use with a 150 hp Yamaha.
