Railing ideas?
mgarvie
Railing ideas?
#1 Post by mgarvie » Sat Nov 10, 2012 8:11 pm
I'm really tired at looking and my old railings and want to replace them. I've never liked the look of the standard railings and wanted something different. I considered steel tubing but the weight seems a bit to much. Anyone else try something that turned out looking nice?
Re: Railing ideas?
#2 Post by Bamaman » Sun Nov 11, 2012 5:28 am
Sounds as if you need a new boat.
1 1/4" aluminum square tubing is readily available, and it's a little easier to bend and fabricate than steel--if you have a TIG welder.
Any boat's railings can be reconfigured. You're only limited by your imagination.
The_Hellbilly
Re: Railing ideas?
#3 Post by The_Hellbilly » Mon Nov 12, 2012 8:07 am
I love the fences on these fiberglass toons
fiberglass 1.JPG (45.09 KiB) Viewed 6379 times
fiberglass 2.JPG (35.51 KiB) Viewed 6377 times
2005 Voyager 22ft Tritoon
2004 Honda 135hp
mgarvie
Re: Railing ideas?
#4 Post by mgarvie » Mon Nov 12, 2012 8:46 am
I like the look of the top one. Is that canvas strapped to tubing?
The_Hellbilly
Re: Railing ideas?
#5 Post by The_Hellbilly » Mon Nov 12, 2012 11:36 am
mgarvie wrote:I like the look of the top one. Is that canvas strapped to tubing?
I believe so. I actually took the pics from a thread we had awhile back on the fiberglass logs. I briefly tried to google the website but no luck.
Found it: http://www.catamarancoaches.com/
2004 Honda 135hp
mgarvie
Re: Railing ideas?
#6 Post by mgarvie » Mon Nov 12, 2012 7:15 pm
I'm still hoping for something that looks better but I'll try this if something better doesn't come up. Should be easy to remove the old sheet metal and clean up the old railings. The fabric seems like and easy DIY project for the winter. At least it won't dent from the asian carp.
MichaelB
Re: Railing ideas?
#7 Post by MichaelB » Mon Nov 12, 2012 9:00 pm
I just replaced the fence on my toon. It was a b.tch... I took the fence sheeting up to the top of the rail and used rivets. It looks real good, just a lot of work.
1984 Riviera Cruiser 28ft, rebuilt and enhanced with 175hp Evinrude
tuned
Re: Railing ideas?
#8 Post by tuned » Mon Nov 12, 2012 9:53 pm
I've got some FischerPrice child gates left over from my first Pontoon. I'll let ya have em real cheap. :biggrin2
mgarvie
Re: Railing ideas?
#9 Post by mgarvie » Sat Nov 17, 2012 10:03 am
Anyone know how to remove the metal panels from the railings of a 1986 Bass Buggy? Looks like the railing is a two part piece and the panels are inserted before welding the two pieces together. If that's the case, it seems the only way to get the panels out would be to cut a big piece out of the middle and pry the edges out with a pair of plyers. Thoughts?
Bamby
Re: Railing ideas?
#10 Post by Bamby » Sat Nov 17, 2012 10:21 am
The panels are usually crimped into the railing before form bending the units as a hole. Get a good still three or four inch putty knife with a fairly sharp edge and using a hammer gently drive it under the crimp to loosen the hold. You'll haft to go along the entire perimeter of the panels to loosen them to remove. And even at that especially at corners it is easiest to cut it into small sections to actually pull it out of the seam.
