engine starts stalling
jcollins
#1 Post by jcollins » Wed Jan 16, 2013 4:24 pm
Newbie I have 1989 70 hp johnson runs good until T push throttle
down engine starts hesitating and feels like it will stall any help please
Ron Burgundy
Re: engine starts stalling
#2 Post by Ron Burgundy » Wed Jan 16, 2013 5:07 pm
Are you running with fresh fuel?
#3 Post by margaritaman » Wed Jan 16, 2013 5:41 pm
Is your fuel vent open?
#4 Post by Bamaman » Wed Jan 16, 2013 6:04 pm
Fresh fuel, fuel vent, check filters, check fuel lines and bulb. Check end of siphon tube in fuel tank. Is fuel good? May need fuel pump rubber membrane and/or carb. cleaning.
Also, when in doubt, change the plugs. Sometimes new plugs can do wonders.
jcollins
#5 Post by jcollins » Wed Jan 16, 2013 6:17 pm
Ron Burgundy wrote:Are you running with fresh fuel?
yes I will check to see if my fuel vent is open Thank you
MH Hawker
#6 Post by MH Hawker » Thu Jan 17, 2013 1:08 pm
Take a real close look at the clip on fuel fittings its real common for those to wear and suck air.
#7 Post by curtiscapk » Thu Jan 17, 2013 1:48 pm
one word......CARBS!
Classic dirty carb symptom. :coffee
#8 Post by Bryden24shp » Thu Jan 17, 2013 3:06 pm
In gear or neutral?
jcollins
#9 Post by jcollins » Sat Jan 19, 2013 8:40 am
Bryden24shp wrote:In gear or neutral?
in gear
#10 Post by Bryden24shp » Sat Jan 19, 2013 8:50 am
Could be a lower unit problem, too. You may be getting a galled thrust bearing. Does everything spin freely in neutral, with the engine shut off? If yes, then I would say, pull the carbs, cause they will really act up more under a load. But check the obvious, first. Pull a little sample of the lower unit oil and see if it looks clean or metallicly. (Is that a word?)
Let us know what you find!
RonKMiller
#11 Post by RonKMiller » Sat Jan 19, 2013 9:25 am
Agreed on the dirty carb, probably a gummed up float needle, but while you've got them out do yourself a favor and rebuild them instead of just clean them. For about $30.00 per kit it's cheap insurance that they'll all be happy for several more years. I mean, 'ya gotta take 'em apart anyway. Go buy a selection of guitar strings - they are perfect for reaming out gummed up passage ways without disturbing the bore. Then shoot some Berryman carb cleaner through each one to remove any final residue, gently blow compressed air through them. :smoke
When you hear hoof beats don't go looking for zebras.
#12 Post by curtiscapk » Sat Jan 19, 2013 10:32 am
RonKMiller wrote:Agreed on the dirty carb, probably a gummed up float needle, but while you've got them out do yourself a favor and rebuild them instead of just clean them. For about $30.00 per kit it's cheap insurance that they'll all be happy for several more years. I mean, 'ya gotta take 'em apart anyway. Go buy a selection of guitar strings - they are perfect for reaming out gummed up passage ways without disturbing the bore. Then shoot some Berryman carb cleaner through each one to remove any final residue, gently blow compressed air through them. :smoke
or speaker wire is what use.
jcollins
#13 Post by jcollins » Mon Jan 21, 2013 11:57 am
Thanks I believe it was the fuel vent. Thanks again
