what type of lock nut is this?
robdew
#1 Post by robdew » Thu Feb 14, 2013 12:40 pm
this is the lock nut off of my prop. I googled around and can't seem to find the name for this type of nut. I want to get a couple spares since it looks like it's somewhat obscure.
the prop drive shaft has two pins and this nut locks into those pins and then you bend up the other two flanges.
This is off an older Mercury Force.
redbeard
Re: what type of lock nut is this?
#2 Post by redbeard » Thu Feb 14, 2013 12:49 pm
Not to be a smart ass but this is a washer not a nut. I believe this is a dealer item. I know someone on the site knows the real name for this washer I just don't remember who it is.
STEVEBRENDA
#3 Post by STEVEBRENDA » Thu Feb 14, 2013 1:05 pm
It looks like some kind of splined washer (a washer to help lock a prp nut in place). I do not know what prop that would fit.
2014 Regency 254
Mercury 250L Verado
stickman
#4 Post by stickman » Thu Feb 14, 2013 1:13 pm
2010 Premier SunSation LTD 225RE PTX triple
220hp 4.3L mpi Merc
Beautiful southwestern Ohio
robdew
#5 Post by robdew » Thu Feb 14, 2013 1:42 pm
yeah searching for it as a washer was much more fruitful. Thanks everyone.
I am just used to props having castle lock nuts with cotter pins I couldn't get the term out of my head.
Gonefishing
#6 Post by Gonefishing » Thu Feb 14, 2013 6:08 pm
This same question was on here a month or so ago. It is a washer. The tabs on it are bent up around the nut once it is tighten down. That way it keeps it from turning. Check some of the past posts for the last one that was posted. They had the correct name for it which I don't remember.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
ubugray
#7 Post by ubugray » Thu Feb 14, 2013 6:43 pm
Had similar ones on my old outboard - merc alpha one drive. They're called tab washers.
2012 18' Sweetwater 1880
2012 Yamaha T50
