First Service
bentleyjc
First Service
#1 Post by bentleyjc » Wed Feb 27, 2013 2:38 pm
Well as warmer weather will be approaching us before too long - its time for my 115's first service soon. I'll be doing it myself.
It's a 2012 Merc 115 4 Stroke - besides changing the oil, oil filter and gear lube - is there anything else I need to do - spark plugs, etc...?
Thanks!
2012 Bentley 220SE Cruise - Black
2012 Merc 115 4-Stroke
"Her Caddy"
Re: First Service
#2 Post by Bamaman » Wed Feb 27, 2013 4:53 pm
Nope. That's about it if everything's going great with the motor.
You'll be good for another year. Just watch your oil level.
Bamby
Re: First Service
#3 Post by Bamby » Wed Feb 27, 2013 6:48 pm
In almost if not all cases you'll also need a grease gun loaded with some good water resistant grease. If you look closely you'll probably observe three or four Zerk fitting that will require a couple of shots each. :thumbsup
Re: First Service
#4 Post by Bryden24shp » Wed Feb 27, 2013 9:07 pm
I would toss on a new fuel filter, too. Just to be safe. They are cheap enough!
Bamby
Re: First Service
#5 Post by Bamby » Thu Feb 28, 2013 8:11 am
I forgot to mention your prop. You will want to remove it and clean out any foreign material and old grease and then liberally apply new grease to the splines and reinstall it again. We don't want our prop galled to the splines should we ever need it off to change it especially out on the water.
Thin Ice
Re: First Service
#6 Post by Thin Ice » Thu Feb 28, 2013 9:49 am
Bryden24shp wrote:I would toss on a new fuel filter, too. Just to be safe. They are cheap enough!
+1
Spark Plugs should be fine. No hurt to pull 'em and clean' em tho
2011 Evinrude E-Tec 115 HO
Full Enclosure
