Upgraded all the incandescent bulbs on my toon to LEDs
Krochus
#1 Post by Krochus » Mon Apr 15, 2013 5:16 pm
I've always wanted to do this on my other boats but never got around to doing so. But my desire to go with led bulbs was primarily based on their longevity and efficiency as a side benefit they're also a great deal brighter.
I changed out all three nav lights and my interior floor lights. The only incandescents are in the gauges now. Replacement led component bulbs were bought at superbrightleds.com with the five bulbs coming in at $37 shipped
Now I have super bright lights that will essentially never burn out that can be left on for weeks without draining a battery. All in all a nice sub $50 mod
I can provide part #'s for the bulbs if ya want although I'm sure they differ from boat to boat.
[size=85][b]2013 g3 suncatcher v20fc "miss-appropriated", 70hp Yamaha four stroke, 2000 ford f250 powerstroke with a stick[/b][/size]
playcat
Re: Upgraded all the incandescent bulbs on my toon to LEDs
#2 Post by playcat » Mon Apr 15, 2013 7:54 pm
Thanks; my barge has 6 old school overhead lights on the upper sundeck. I don't use them much because they drain too much juice. About those part numbers... :wink:
playcat
JC 266 TriToon
Kerr Reservoir, VA
peedee
#3 Post by peedee » Thu Apr 18, 2013 7:38 am
So can you just swap out bulbs, or do you need some other type of device to lower the wattage along the way.
2005 20' Tahoe
50 Yamaha 2 Stroke
cwag911
#4 Post by cwag911 » Thu Apr 18, 2013 8:19 am
Just swap out the bulbs. I got mine from here: http://www.superbrightleds.com
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
GXPWeasel
#5 Post by GXPWeasel » Thu Apr 18, 2013 8:45 am
peedee wrote:So can you just swap out bulbs, or do you need some other type of device to lower the wattage along the way.
Yep, just swap out a bulb, with a comparable based LED. The only time you need any type of load drop, is when dealing with blinkers. Most times, if you replace your cars blinkers with LED's, the flasher thinks you have a bulb burnt out, because of the such low resistance, and the flasher either won't flash, or it will flash really fast.
#6 Post by curtiscapk » Thu Apr 18, 2013 8:51 am
WOW Greg's back!!!!!
:thumbsup :thumbsup
GXPWeasel
#7 Post by GXPWeasel » Thu Apr 18, 2013 9:07 am
:thumbsup :thumbsup
Been a while, I know. Been busy at work, moving to a new house, and trolling gun sites.
I was just in your neck of the woods last weekend there Curtis. Had to check out Shawnee Bend golf course there by Warsaw. :biggrin2
