Why is my transom a "flooded" design?
RonKMiller
#1 Post by RonKMiller » Thu May 16, 2013 8:28 am
My 1988 Party Hut's transom has a purpose built hole in the rear bottom to allow water in and out, and the transom "flooded."
What's the purpose of this - to provide damping/sound reduction for the motor? It seem counter intuitive since that section - if sealed off - would provide about another 150 lbs. of buoyancy, not to mention keep the plywood the motor is mounted to out of the water.
Yep, this stuff does indeed keep me up at night! :paranoid
Re: Why is my transom a "flooded" design?
#2 Post by curtiscapk » Thu May 16, 2013 8:30 am
Same way!
MPosey519
#3 Post by MPosey519 » Thu May 16, 2013 8:38 am
ditto on mine!
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
#4 Post by HandymanHerb » Thu May 16, 2013 8:44 am
I think because of splash you would be filling it up, but I was think about sealing that hole up too but I don't think you gain that much in floatation
PlaynDoc
#5 Post by PlaynDoc » Thu May 16, 2013 9:45 am
I have no idea why mine is like that either, but here's my guess...
When they designed the transom, and how it would affix to the boat, the best engineered drawing resulted in the V pattern seen on almost all pontoons. Well, if you leave the bottom of the V sealed, it fills with water, so the hole is needed. As a closed device, no significant buoyancy added. While open, gives a protected place for wires/fuel line to run/lay as they go from boat to motor.
For me.... it's where I toss my plastic wheel chucks when moving the trailer! They get the caked-on mud, spiders, ants, and other crap, washed off while being stored where they are readily available. It is also going to be where I place my strainer/water intake piping for my wash down/live well fill pump!
BobG
#6 Post by BobG » Thu May 16, 2013 9:51 am
RonKMiller wrote:What's the purpose of this
<BS>
Well, if you follow bernoilli's third principle, the open rear of your transom creates a "hydro-vacuum", which in turn generates a negative pressure wave inside the transom, causing an INCREASE in air pressure around your motor, essentially acting like a supercharger, then closing the loop via the boats exhaust system. This phenomenon, known by boat designers as a "suckercharger", was developed during world war two, and was a top-secret feature of the (of course, top secret) assault pontoons, which were air-dropped into the Bodensee in Switzerland, to assassinate vacationing SS and Wehrmacht officers. The technology was so successful, that nobody survived to tell about them.
</BS>
Beats me... :happy
But the Admiral thinks it's the ladies loo...
PlaynDoc
#7 Post by PlaynDoc » Thu May 16, 2013 9:55 am
<BS>
</BS>
Beats me... :happy
<bs>WOW... now I'm impressed... the vast empire of your knowledge astounds my mere human brain.....</bs> :bowdown
slingshot
#8 Post by slingshot » Thu May 16, 2013 10:55 am
I think it's a simple as needing to get to the motor mount nuts in order to install the outboard on the transom of the pod. In order to assure that water wouldn't get in the pod from the top you would have to seal it some how. If you did that you can't easily access the mounting bolts. Mine has the fuel tank mounted in it. When I'm underway the water drains out the hole but at idle it'll fill up.
2007, 2570 Crest LE II
Yamaha F150
evinrude2stroke
#9 Post by evinrude2stroke » Thu May 16, 2013 11:20 am
I was always wondering about that also. :donno
My friend has a Tracker which also has the fuel pod built inside the transom. I get the idea of having access to the motor mounting bolts. But I wonder why creating a fuel tank for that space wouldn't be the norm nowadays. Seems like a good idea.
Dave
GXPWeasel
#10 Post by GXPWeasel » Thu May 16, 2013 12:11 pm
evinrude2stroke wrote:I was always wondering about that also. :donno
Yep, would save a bit of valuable space elsewhere for speakers... :nana
PlaynDoc
#11 Post by PlaynDoc » Thu May 16, 2013 12:19 pm
OR.... a keg-orator
BobG
#12 Post by BobG » Thu May 16, 2013 12:25 pm
PlaynDoc wrote:OR.... a keg-orator
I think the constant vibration of the transom would make it a foam-er-ator! :scared
ToonGuy
#13 Post by ToonGuy » Thu May 16, 2013 12:48 pm
Isn't it :donno At least all the higher end toons all have transom mounted tanks...
RonKMiller
#14 Post by RonKMiller » Sat May 18, 2013 6:21 am
Have I stumped the EXPURTS on this one? :biggrin2
It just doesn't make ANY sense, although I bet it keeps the sound/vibration levels way down.
Yep, that's got to be it. :drink4
Either that or it's some sort of OBAMA plot. :eviltaunt :happy
Bamby
#15 Post by Bamby » Sat May 18, 2013 7:20 am
My guess is for one, cheaper or cheapest design to manufacture. Two eliminates any need for a bilge pump to keep water evacuated. Three it eliminates the worry of water freezing up and breaking things over winter storage. Four it does away with accumulated stale stinky mosquito infested water in ones transom.
I could probably come up with some more.. :lol3 Anyway under power your transom drains out or evacuates to empty through the drain hole. I actually increased the diameter of mine some so it will actually drain faster.. :thumbsup So I'm not thinking the accumulated water theory is in reality "holding any decibels" :roll:
