12 volt power outlet issue
$mitty
#1 Post by $mitty » Tue Jun 25, 2013 10:53 am
Hello
Have a problem with my 12 volt power socket on my pontoon. I have a 2008 24 foot sunchaser with a 90hp 4-stroke EFI, every time a plug something into it it blows the adapters. I have a couple cell charger it blew, a small car inverter, etc. It's not blowing the fuse in the boat though. Picture below shows socket. Any thoughts?
redbeard
Re: 12 volt power outlet issue
#2 Post by redbeard » Tue Jun 25, 2013 11:15 am
Take the plug apart and look for rust.
MH Hawker
#3 Post by MH Hawker » Tue Jun 25, 2013 12:29 pm
check the voltage polarity, I bet its reversed
jrolin1
#4 Post by jrolin1 » Tue Jun 25, 2013 2:15 pm
MH Hawker wrote:check the voltage polarity, I bet its reversed
X2! Easy for them to make that mistake on a boat where you have to hook up the ground.
$mitty
#5 Post by $mitty » Tue Jun 25, 2013 4:05 pm
Is it a difficult fix? Something the dealer is going to have to do?
Thanks for your help guys.
#6 Post by HandymanHerb » Tue Jun 25, 2013 4:29 pm
Should be plug in conections, if not cut and splice them to the right poles, center of the plug is the + the sides are -
#7 Post by Bryden24shp » Tue Jun 25, 2013 5:29 pm
That will fix it! They just wired backwards... It is a :nutkick , though! Now you have to get new chargers... I'ld tell the dealer that its messed up from the factory. doubt you'll see anything, but at least they will know that it was f'ed up and you are not happy.
megawatt
#8 Post by megawatt » Wed Jun 26, 2013 4:48 am
I had the same problem right after I purchased my toon. As everyone has said, I found that the factory had wired the 12V socket backwards. I wish every electrical problem was as easy to fix!
Richland-Chambers Reservoir, North Texas
2005 Harris FloteBote SuperSunliner 23' Tri-toon
Honda BF150
MinnKota PowerDrive V2 trolling motor w/i-Pilot
$mitty
#9 Post by $mitty » Wed Jun 26, 2013 6:29 am
Thanks everyone. I will attempt the fix. wish me luck! :nana
The_Hellbilly
#10 Post by The_Hellbilly » Wed Jun 26, 2013 8:20 am
The guys above are most likely right, but if it's not that, check the wire & fuse size. It's not uncommon to find the outlets underpowered for today's needs
2005 Voyager 22ft Tritoon
2004 Honda 135hp
