Ladder Suggestions
- Lifesatripp
Ladder Suggestions
I am looking to get a foldable ladder for my side and flat front pontoon. I would have it on the front or side depending on where I will be using it the most that day and buy an extra mount kit. I like the looks of the versatility of this ladder on overtons but Im wondering if it will work on the front as well as the side of the toon? Any ideas if this would be good to use on either or any other recommendations?
- 38805_L1.jpg (1.15 KiB) Viewed 1194 times
'Life's A Tripp'
2008 Bentley Cruiser 220
2008 Mercury 60 hsp 4stroke
Relaxing on the St Lawrence
Re: Ladder Suggestions
IT works great. I haven't had it on the water yet but it is very sturdy and should work on any side but ussing the front wouldn't have the toons for support.
Use pontoonstuff though! 10% discount
http://www.pontoonstuff.com/folding-pon ... adder.aspx
- SAM_0972.JPG (242.33 KiB) Viewed 1167 times
- SAM_0971.JPG (286.32 KiB) Viewed 1164 times
I have that same ladder. It works good on the sides but I dont think it would work well on the front without any lower support. I just use it on the sides for when we are out by ourselves. If we are rafted up with other boats, there is always another boat with a ladder front or back that we can use.
Darin and Karri
Beaver lake Arkansas
I like the under the deck ladder I got, stays out of the way, then you just slide it out when needed, and it goes deep enough to make it easy to get on
