no Prop numbers, plz help!!!!!
LisanJohn
#1 Post by LisanJohn » Tue Jul 23, 2013 5:29 am
I have a prop question. my prop has a big chunk missing out of one of the blades and the repair shop says it will be about $135. I'm sure I can get a new one cheaper online. problem is I cant read the numbers on it at all. I have a 1989 40hp evinrude on a 20 foot toon. need an idea where to even start with what prop to get?
This Is just another of my many obsessions in which a vacuum is created in my wallet
OK Toon
Re: no Prop numbers, plz help!!!!!
#2 Post by OK Toon » Tue Jul 23, 2013 6:14 am
Have you removed the prop? Mine didn't have any identification numbers anywhere that I could see when the prop was on the motor. Once I removed it, I found a stamped number on the backside.
Is the prop aluminum or SS? If aluminum, $135 would buy you a new prop online. SS will run about $400 or more online. I had my aluminum prop repaired and repitched for $80 at a local prop shop.
You might just have to go to the Evinrude site and see what is recommended for that motor/boat combination.
LisanJohn
#3 Post by LisanJohn » Tue Jul 23, 2013 7:39 am
ok its a 3 blade aluminum prop and I can see where the numbers used to be be they are so worn off. I even tried to remove the paint but still nothing..
#4 Post by HandymanHerb » Tue Jul 23, 2013 8:36 am
You have a 12.5 x 13 is what was on my 50, and you can't buy cheaper than that repair and it will come out new, are you dealing with the prop shop or the mechanic ?
One thing about dealing with the prop shop, you tell them what it's used on and they can fine tune it for your boat.
LisanJohn
#5 Post by LisanJohn » Tue Jul 23, 2013 10:22 am
just took it to my local marine shop. maybe you know of them, It Nobels in Leesburg
#6 Post by HandymanHerb » Tue Jul 23, 2013 1:32 pm
Heard of them, I also found I-boats have good prices on new props with no shipping for ground shipping, so you can get a spare cheap
http://boatpropellers.iboats.com/Evinru ... =930810087
