Two strange things with Merc 90HP four stroke today
wrd1972
#1 Post by wrd1972 » Mon Sep 02, 2013 5:25 pm
1. Upon startup, I saw some very black oil discharge (dots) get spit out into the water, likely through the prop. I don't think its engine oil because I purposely dropped some engine oil into the water from the dipstick and it had an entirely different appearance. It was not dark at all, it just was more colorful and different looking. I have not yet checked the level of the lube in the lower unit. If its lower unit lube, why would it appear at startup before the prop is engaged?
2. Started the motor with it in a rather warm state, and saw white smoke coming out of the plastic case and maybe the pee-hole. I think it was steam or again white smoke and not blue smoke from burning oil because I noticed no smell of burning oil. Went away after a short while and has not be repeatable. I have never detected the smell of burning oil. What was that?
oldmn19
Re: Two strange things with Merc 90HP four stroke today
#2 Post by oldmn19 » Tue Sep 03, 2013 6:19 am
You broke it,LOL, just kidding!!!!! It might, and just a guess, have spit out some rich fuel burn from a temporary drippy injector. If's it now running cleanly and doesn't repeat, I would still add a good injector cleaner to your next fill up, can't hurt! :2cents
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
#3 Post by lakerunner » Tue Sep 03, 2013 7:49 am
oldmn19 wrote:You broke it,LOL, just kidding!!!!! It might, and just a guess, have spit out some rich fuel burn from a temporary drippy injector. If's it now running cleanly and doesn't repeat, I would still add a good injector cleaner to your next fill up, can't hurt! :2cents
Yes and that bit of gas dissolved some carbon and blew it out. The white is likely warm water hitting cooler air
brumbyvet
#4 Post by brumbyvet » Tue Sep 03, 2013 4:51 pm
Mine has done the same thing occasionally, since boat was new. It usually happens after I have had the motor tilted up, out of the water, for a week or more. Mechanic said not to worry about it and I haven't.
36 mph gps...
Cherokee Lake, Tennessee
U.S. Navy 1971-1977
