So what is the next best place for the transducer?
Do the logs present any problems for transducer operation? I am thinking about making a mount for it from pvc pipe that I bolt to the front of the pontoon, on the right hand side of the bow. This would be very easy to do, easier than having a mounting position welded to the pontoon frame.
But I am unsure if the bottom of the transducer needs to be lower than the bottom of the logs to operate properly.
Any suggestions will be appreciated.
Ed
