Trailer Back Up Camera
brianD
Location: Live in STL, Boat wherever there's enough water to not mess up a prop.
#1 Post by brianD » Tue Apr 01, 2014 1:37 pm
So last fall took the family boatster to Table Rock Lake (incredible lake by the way). Launched the 27.5' behemoth of a tritoon, we like to call "2nd Honeymoon", and my wife pulled the trailer up the ramp to drop it at the 'trailer lot'. :nana
In her defense, it was raining just a bit, and visibility down the length of a 30+ foot trailer is limited, even though we have the Smith uprights with lights at the back. To make a long story short, she backed it into a tree, and broke one of the little bitty plug in market lights on the back of the trailer. :scared
Truth be told, she maneuvers that trailer like a pro most of the time. She backs me in, I unhook the bow, she give me a little 'run and bump' and we're off the ramp in like 12 seconds. :)
Anyway, she felt really bad about 'trashing the trailer' so I said, what if I could give you a backup camera. BOOM! The only Member of the Admiral's "Funds Appropriation Committee" voted, and the quest was on... :biggrin2
So I found a cheap LCD screen, and submersible camera from one of those Japanese sites to use as a prototype. Turns out the prototype was good enough quality to move to production. Little bitty camera (about 1" x 1" x 1" without bracket)with LED lights for night vision, and a decent 4.5" screen for the dash that plugs into the cigarette lighter.
Mounted the camera on the bottom of the rear cross member of the trailer, ran RG6 Quad coax up to the tongue through the frame, and then ran another piece of the same from the dash to the hitch. Then I mounted a couple of Coax screw terminators (one to the hitch, and one to the trailer), I have a replaceable one that ties the two together, and since it will do all the moving, can be replaced if it breaks.
then there was the issue of how the hell am I going to get power back there... Then it hit me. a 5 pole trailer plug has a lead tied into the backup light circuit. New 7pin round to 5 pin flat adapter, ran wire down through the frame, to the camera, and voila. Put it in reverse, and you can see just what the prop sees.
Whole thing was a little over $100. :alright :alright
If anyone is interested in Pics, I'll post them, but I thought it was a pretty slick installation to solve the problem of seeing behind a wall of aluminum or just a long ways behind you.
b
2006 Landau Excalibur 2700
225 Suzuki 4 stroke
2011 Bear tandem trailer
2011 3/4 ton Suburban
Re: Trailer Back Up Camera
#2 Post by lakerunner » Tue Apr 01, 2014 2:21 pm
pic's
#3 Post by curtiscapk » Tue Apr 01, 2014 2:25 pm
Fantastic! Post them up! I have been thinking of trying the same thing!
SeaBreeze
#4 Post by SeaBreeze » Tue Apr 01, 2014 3:51 pm
I installed a similar backup camera on the back of my 24' Bayliner cruiser's trailer, otherwise I do not know how one would back it up in a lot without hitting something. BTW, the one I had was not waterproof, I removed it when not trailering and right before I backed into the water. I have backup camera's on all my vehicles now.
2012 Cypress Cay Seabreeze 230 Fish 90hp Merc
Lifting strakes and under skinned
brianD
#5 Post by brianD » Tue Apr 01, 2014 5:32 pm
this one is IPX6 waterproof, and it's not in the water that long. I don't have to remember to remove it.
As requested here's some pics. Works really well.
Looks like I put them in ass-backwards order, but you are all smart and can see how it works. :scared
Hardest part was feeding the power line through the loom without messing it up, and then soldering to the blue wire (backup lights)
5 wire connector.jpg (95.78 KiB) Viewed 1972 times
This is how far I am from the back, you can compare it to the grid on the display
The grid is pretty helpful, you can see my prop in the display. the redness is from the brake lights.
Display with grid.jpg (82.51 KiB) Viewed 1971 times
When you put it in reverse, the lights come on and the camera starts sending video
camera with lights on.jpg (61 KiB) Viewed 1973 times
the display sits on the dash and plugs into the cigarette lighter, and the long coax from the back of the 'Burban. I can remove it so Heathens don't get curious.
Display on dash.jpg (82.5 KiB) Viewed 1974 times
Little bitty thing but works well
camera size.jpg (52.38 KiB) Viewed 1971 times
On the trailer side, I put a connector so that I could replace the only moving wire if/when I need it
Trailer side.jpg (111.86 KiB) Viewed 1971 times
I put these caps on to keep the funk out
Truck side with Cap.jpg (102.7 KiB) Viewed 1971 times
Here's where I' mounted it
Truck side position.jpg (95.98 KiB) Viewed 1969 times
b
225 Suzuki 4 stroke
#6 Post by Bryden24shp » Wed Apr 02, 2014 2:19 am
Looks good! I bought a cheap "Peak" brand wireless B/U camera for the trailer. Works real good. I like to see what I can't see in the mirrors, when I'm towing long distance. And it makes it a lot easier when maneuvering around the fuel pumps and parking lots at the truck stops along the way, too. It also saved me a from buying a new TFD. I saw it blow out of the boat on the display. It didn't say if the camera was waterproof on the package, so I sealed around it with sillycone, just to make sure.
tuned
#7 Post by tuned » Wed Apr 02, 2014 3:16 am
Beauty install!
I use one at my bow to see my power anchor. I can't stand running and not knowing that it is up and secure. It helps alot when bringing the anchor up as well. Handy little devices for a lot of miscellaneous uses I'm thinking
brianD
#8 Post by brianD » Wed Apr 02, 2014 11:46 am
I initially tried to do the wireless thing. I have the TX and RX, but neither said they were waterproof, and it wouldn't reach from the back of the trailer to the dashboard, and I still would have had to run power, so not even so much wireless :donno I don't have backup lights on my trailer so had to go front to back with power. If I already had those, it may have been easier.
When I'm fully hooked up, I'm 53 1/2 ' long from front bumper to prop, so that's quite a distance for those little Japanse 2.4Ghz transmitters. Maybe with a much better (read $$) TX/RX setup it would have worked better for me.
I found that using the heavy Coax (RG6Quad), while difficult to fish through the trailer rails, gave me a much better signal at the dash (i.e. no snow or cutting out)
b
225 Suzuki 4 stroke
