Front Bimini for toon
Gonefishing
Looking at adding a front Bimini to my toon. Checked with the dealer and manufacture they want 1700. Seems like a lot to me dealer said it is cause everything will be the same as the rear. What do others think is a aftermarket just as good?
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
Re: Front Bimini for toon
Ferg's Tritoon Build
I should also clarify. I can't attest to any other sites quality. My only reason I ordered from where I did is because they had black canvas at the 8'6" wide option. No other sites I found had that listed at the time.
I too bought my 8 1/2' wide second bimini from pontoonstuff.com. i asked for 'something free' to be tossed in... so, along with the 10% discount, i got a free tshirt!
my 'factory' bimini is 8' long; i moved it to the front; put a 10' one in the back.
you're being ripped off. for that kind of money, you can almost get two electric ones!
i figure, as long as the frame is 1 1/4" square tubing, and the fabric is Sunbrella... you can't go wrong.
click the ONLY advertisement this forum has... the link is in the top right corner..
I ordered a Taylor made gazebo, Bimini buddy clamps and plan to install it when I get free time next week.
Go with the after market like PlaynDoc said just make sure it has Sunbrella fabric one of the best buys I've made.
http://www.vortexdirect.com/ very pleased with this co and its parts.
- top3.jpg (429.4 KiB) Viewed 3799 times
- top_boots.jpg (475.49 KiB) Viewed 3800 times
30ft party barge,225 black max,tritoon- north alabama- my faster ride 572cu alky inj mopar
Yep, my bow bimini is a Vortex, pleased so far.wedge542 wrote:http://www.vortexdirect.com/ very pleased with this co and its parts.
- rhorne
Is there a difference between the front and rear tops or does the rear fit on the bow?
[b]If you can read this thank a teacher.
If you are reading it in English thank a Veteran.[/b]
2014 Tahoe LT Cruise 2300
2014 Evinrude Etec 250 HO
2008 Stratos 294 XL
2012 Evinrude Etec 225 HO
2008 Stratos 294 XL
when i bought both mine at same time they was same but if you wont you can get the two with a zipper to connect the two if you liked that way. I looked for few weeks before buying and compared everything i found as far as materials, cost, complete kit form, installation,other reviews,shipping cost.
- rhorne
Thanks, I already have one on the rear (factory)
2008 Stratos 294 XL
2008 Stratos 294 XL
I have the factory Sun Tracker stern bimini. Tracker wanted $750 to add a bow bimini
These were $200 on eBay, color doesn't exactly match, but I'm not a picky bastid anyway
I don't know about just as good but I bought one on Ebay for $199.00 two years ago and it still looks great and works as well as the factory top. The material is not quite as thick as the factory top but it's actually been more mildew resistant than the expensive on.Gonefishing wrote:Looking at adding a front Bimini to my toon. Checked with the dealer and manufacture they want 1700. Seems like a lot to me dealer said it is cause everything will be the same as the rear. What do others think is a aftermarket just as good?
(old) 2000 Sylvan 20' Tritoon
The first owner of my Suntracker bought the factory stern top and had the dealer install it. They seemed to have just reversed it 180 degrees. Don't recall the cost, not cheap, but the tops zipper together for a seamless 20' cover.badmoonrising wrote:I have the factory Sun Tracker stern bimini. Tracker wanted $750 to add a bow biminiThese were $200 on eBay, color doesn't exactly match, but I'm not a picky bastid anyway
2010 Suntracker 24' Sunchaser
2009 Mercury 90hp EFI/4S
2007 Ford Expedition 4WD
