What does this involve? You can talk to me like I'm 4, because that's about my knowledge level.
I believe our boat is made for two (we were told it was). There're spots for 2, but only one in there. I do NOT see the connections for another though. We do have the switch on the console for it.
Going from one battery to two
Re: Going from one battery to two
We don't have a sound system with a giant power amp, and there's no trolling motor on my boat.
I prefer to use a single auto style battery. They last so much longer in marine use, and are just a better all round value if you don't need the deep cycle functions of a trolling motor battery.
If you go two batteries, you need at the least to have a Perko battery isolator (switch) installed.
My PowerStroke diesel pickup has two batteries, and it cost me almost $400 to change them earlier this year. I don't need two more batteries to replace in the future.
If I knew who to credit for this picture, I would. I may have just found it on the internet, but I don't remember. Good luck to you. (We have a second battery and glad we do.)
- StandardBatterySwitchWiring.jpg (27.35 KiB) Viewed 1892 times
2010 Premier SunSation LTD 225RE PTX triple
220hp 4.3L mpi Merc
Beautiful southwestern Ohio
220hp 4.3L mpi Merc
It's fairly simple to add the 2nd battery (as shown in the picture). You can also add a Voltage Sensitive Relay to ensure you'll always have starting power. This may not be a big deal if you don't run much of anything on your boat. I went ahead and did it just to be safe.
here's the VSR / Switch setup I purchased.
http://www.ezacdc.com/boat-wiring-produ ... h-systems/
Pics of install.
Pics of install.
Ferg's Tritoon Build
Looks like one of Silvertip's pictures from iBoats.stickman wrote:If I knew who to credit for this picture, I would. I may have just found it on the internet, but I don't remember. Good luck to you. (We have a second battery and glad we do.)
Mercury 90 4 stroke
Mercury 90 4 stroke
I have the same system as fergusmj has and love it. Seems like the way to go,
had mine since the beginning on this boat.
