Inline fuse keeps...
Hello All.
Up here on beautiful Lake George, NY with the whole family, father-in-law, brother-in-law and nephew too. Boat is running great (thank you Jesus)... However, the inline fuse to my Garmin GPSMAP blows as soon as I install it. Looked around yesterday "under the hood" and everything looks good, can't see any obvious shorts. Do you have any experience with this or intimate knowledge of such a problem? Can't go for a night cruise without it. Thanks so much.
Sincerely,
Rich
Sincerely,
Rich
Rich and Annemarie Bias
2007 Merc 75 4 Stroke
2006 Honda Pilot
2006 Honda Pilot
Re: Inline fuse keeps...
If this is just the fuse for the gps then I would think you have a problem with the gps. I would trace the wire from the unit back to the fuse.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
- Capt Sully
Yep, sounds like a short in the wiring some where ? maybe a bare wire is touching something ?
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
Gonefishing
If it is just the gps fuse then it is a bare wire somewhere between the fuse and the unit
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
If the unit un plugs I would start by doing that and see if it pops
Check the connector and the back of the unit to make sure the pins haven't been damaged or any debris in the connector. Otherwise it doesn't sound good for the GPS.
- NonHyphenAmerican
Fuses pop for a reason.
Find the reason and the fuse will quit popping.
Either there's a short between the fuse and the gps or there's a short in the gps.
stick a .22 magnum shell in the spot for the fuse, and keep on trucking!
Thanks all!
Especially to PlaynDoc...
I do believe it is the harness that came with the unit. I don't want to think that but like you said. fuses pop for a reason. I guess I will get a new harness and figure a way to keep it out of the weather, even though I was religious about keeping the rubber cap on it. Thanks again and will be posting amazing pictures soon from beautiful Lake George, NY. Thanks again...
Sincerely,
Rich
Sincerely,
Rich
2006 Honda Pilot
2006 Honda Pilot
