Inside motor fuel line replacement help needed.
paleojoe
#1 Post by paleojoe » Tue Jul 08, 2014 4:31 am
Engine is a 2005 Mercury,90hp, 3cylinder.The fuel line that runs inside the motor has split and I can not seem to find a part number or what it is called on line. The line has a outlet in it that is plugged off, then it branches off in a Y. Looks like one goes to high side and one low? I have it so it will work now, but want to replace it with the correct line. Thank you for your help !
Re: Inside motor fuel line replacement help needed.
#2 Post by badmoonrising » Tue Jul 08, 2014 3:53 pm
This is a very good site for diagrams/parts for Mercury/Mercruiser. To better find the right part, you need your serial number:
http://www.mercruiserparts.com/Show_Pic ... =Fuel+Pump
What I do is use this site to get the part number, then search for it online (eBay, etc.) to find the best price.
#3 Post by Bamaman » Wed Jul 09, 2014 2:03 am
If you're dealing with bad fuel lines going to or coming from your fuel pump, you should consider disassembling the fuel pump. The rubber membrane inside is susceptible to deterioration from 90/10 gasoline, and I'd suggest replacing it as a maintenance item.
As you can tell from the picture, fuel pumps are pretty simple animals. There's a hole on the back that gets pulsating air from the crankcase as the engine turns over. It pushes the rubber membrane in and out sucking the gasoline through the hoses.
#4 Post by Bamaman » Wed Jul 09, 2014 2:04 am
paleojoe
#5 Post by paleojoe » Wed Jul 09, 2014 5:51 am
Thanks to all ! :biggrin2
