WOT Slower than lower RPM...
SeaBreeze
#1 Post by SeaBreeze » Sat Jul 26, 2014 1:51 pm
First time I have had the oppourtunity to travel a distance at WOT but found my best speed was at 6000 RPM vice 6300. It has a stock Merc prop.
2012 Cypress Cay Seabreeze 230 Fish 90hp Merc
Lifting strakes and under skinned
jrolin1
Re: WOT Slower than lower RPM...
#2 Post by jrolin1 » Sat Jul 26, 2014 7:37 pm
It should not be that way unless your hub is slipping. I could understand it if it is not much faster at wot, but not slower.
#3 Post by Bamaman » Sat Jul 26, 2014 7:49 pm
I take it the GPS is running in KPH instead of MPH with 90 hp.
#4 Post by Bryden24shp » Sun Jul 27, 2014 2:23 am
I bet the prop is cavitating a little bit at WOT. Did you try to bring the trim down a little to get it to bite at all?
SeaBreeze
#5 Post by SeaBreeze » Sun Jul 27, 2014 2:29 pm
Bryden24shp wrote:I bet the prop is cavitating a little bit at WOT. Did you try to bring the trim down a little to get it to bite at all?
It could be cavitating a little, I was seeing about 29mph at 6300 rpm, I trimmed up and down but just lost speed both directions so that was as fast as I could get it at WOT. As I slowed down the rpm a little it picked up .2-.3 mph.
And, no I do not have my GPS set on KPH. I am in the ballpark of what the dealer said I would get with underskin and lifting strakes (their version of perfomance package).
#6 Post by Bryden24shp » Sun Jul 27, 2014 4:36 pm
When you are running WOT, have someone steer for you and run back and see how far the prop is in the water. Look at the cavitaion plate on the L/U and see if it is running out of the water. With the new prop I just ran, the cav plate was about 3" out and I could hear the props ears slapping the water. If you are little too far out, it will ventilate.
Tlowry
#7 Post by Tlowry » Mon Jul 28, 2014 1:58 pm
Bamaman wrote:I take it the GPS is running in KPH instead of MPH with 90 hp.
I think 29.2 is believable.
Sounds like it's starting to suck air at the higher RPM to me too.
