Is there reverse lock out in an outboard?
willy13
#1 Post by willy13 » Sat Aug 23, 2014 8:41 am
A less experienced driver was pulling a tuber last weekend. The tuber signaled to cut the motor and the driver got a little anxious and put the motor into reverse before stopping (from 4500 rpm). :nono I did not hear any bad sounds but the motor did stall out. Is there some sort of safety device to keep this from happening on outboards? Any chance of hurting the motor?
MH Hawker
Re: Is there reverse lock out in an outboard?
#2 Post by MH Hawker » Sat Aug 23, 2014 12:32 pm
Not that I know of and yes it can destroy a LU.
teecro
#3 Post by teecro » Sat Aug 23, 2014 4:43 pm
Why would you want to put a lock on your brakes?
Not even tug boats and ships have any means of locking out reverse as that is our only means of stopping quickly.... Timing systems we have but no means of locking out would be tolerated....
willy13
#4 Post by willy13 » Sat Aug 23, 2014 8:17 pm
teecro wrote:Why would you want to put a lock on your brakes?
Because going into reverse when the engine hasn't idled down may not be good for the motor. It certainly would not lock out reverse when the engine is at a low enough RPM.
jrolin1
#5 Post by jrolin1 » Sun Aug 24, 2014 6:08 am
On my Yamaha the throttle has a red lever that must be pulled to put it in gear so you would have to be pulling it to switch from fwd to reverse. It pops out at the neutral position.
