Posi-Lube spindles?
Posi-Lube spindles?
My new Magic Tilt Trailer is equipped with the posi-lube spindles. Last week I was shooting a couple of shots of grease to one of the hubs and the zurk fitting just pulled out and was still attached to the grease gun. The fitting threads were stripped and the fitting was not what I am used to seeing. The fitting shoulder where you would have a hex head was all round. There was no way a socket wrench could have screwed this on. Anybody have any experience with this? I guess I need to figure out what the thread is supposed to be and run a tap in the hole to see if I can get another fitting in there.
2014 V22C G3
2014 Yamaha 90 HP
2015 RAM 1500 4X4 EcoDiesel Tow Vehicle
2014 Yamaha 90 HP
Re: Posi-Lube spindles?
Yep, they are pressed in fittings. I had some on a different piece of equipment. Tap it out and thread one in.Flattop wrote:My new Magic Tilt Trailer is equipped with the posi-lube spindles. Last week I was shooting a couple of shots of grease to one of the hubs and the zurk fitting just pulled out and was still attached to the grease gun. The fitting threads were stripped and the fitting was not what I am used to seeing. The fitting shoulder where you would have a hex head was all round. There was no way a socket wrench could have screwed this on. Anybody have any experience with this? I guess I need to figure out what the thread is supposed to be and run a tap in the hole to see if I can get another fitting in there.
2008 SunTracker Fishing Barge signature series 21/60HP Bigfoot 4 Stroke EFI, 85# Thrust Minn Kota Terrova Trolling motor W/Remote control and foot pedal
