Polished My 'Toons! Before/After Pics
Finally had a day off and some nice weather. Went to Fleet Farm and bought a variable speed buffer and a polishing pad. Used Blue Magic Aluminum Polish (good stuff!) and went to town. Started at about 8:30am and finished about about 1pm with a few sammich breaks in between.
Here are the before and after pics.
- after1.jpg (68.36 KiB) Viewed 6217 times
- before2.jpg (59.58 KiB) Viewed 6218 times
- before1.jpg (58.04 KiB) Viewed 6220 times
_________________________
Buy the ticket - Take the ride.
- H.S.T.
- H.S.T.
- FloterBoter
Re: Polished My 'Toons! Before/After Pics
nice!
now you're ready to mount the tap fins.
You think they'd be beneficial on a tri-toon with factory lifting strakes?FloterBoter wrote:nice!
- H.S.T.
- H.S.T.
Sweet that looks good maybe I'll bet polishing bug too.
NO NOT MORE TAP FINS!!!!!!!!!!!!!!
I can't see the after pics
Now that you've polished, make sure and apply Sharkhide before you put it in the water. Polished mine last spring and applied Sharkhide, looks just like it did when i finished.
2007 Playcraft Powertoon 2400
I'd rather be lost at the lake than found at home.
Now I can see them. Looks great. If you tire of having the Bimini laying on your rear deck pad when in down position I have a fix for that. If interested I will get some close up pics of my modifications.
You can see what I did with uprights in rear. I leave the dark part attached to rail and unbolt and lay top inside slots. Keeps top off pad yet down for towing and nice weather. I can access changing room in down position
Oh hell yeah - that looks sweet. Any info would be appreciated. I was not crazy about towing with that thing bouncing around all the time. I also need to relocated the white light that's on the bimini.lakerunner wrote:Now I can see them. Looks great. If you tire of having the Bimini laying on your rear deck pad when in down position I have a fix for that. If interested I will get some close up pics of my modifications.
- H.S.T.
- H.S.T.
Bimini light bracket
Bimini rear support change
Very nice man! Thanks for the ideas - I love the rear light bar.lakerunner wrote:Bimini light bracket
- H.S.T.
- H.S.T.
