What is the best jack plate to use on a 93 24 ft sun tracker party barge with a 2003 Johnson 90 HP? I was wondering how much setback also I was thinking manual adjust because of price....
Thanks for any advice......? I was
jack plates
- chopper6358
jack plates
1998 Crest 25' Tritoon,115 Johnson 2 stroke. 13x11 4 blade spitfire prop, pulled with 2007 GMC sierra classic 2500hd 4x4. ky lake :nutkick :thumbsup :eviltaunt
Re: jack plates
Why do you need one?
Re: jack plates
Got to wonder the same thing? A 24 foot party barge with a 90 HP is not going to be setting no speed records no matter if it's jacked up or down. Where does your cav plate run while your underway?lakerunner wrote:Why do you need one?
Re: jack plates
Two reasons I would want a jackplate:
To be able to raise motor for shallow water operation.
To allow motor to be adjusted for fine tuning speed and operation.
The set back is of no consequence, most motors are set back from the factory these days, I think its a good thing for handling.
My opinion is you can adjust the motor with the mounting holes good enough for the performance of the hp you have.
Jackplates aren't cheap id say spend the money on a good gps sonar or sumpn!
