Propeller
Reiner
Propeller
#1 Post by Reiner » Sun Dec 14, 2014 9:40 pm
I currently have an Enertia 15.125 x 14 SS prop on my 2014 Merc 150 HP outboard (part# 48-898988) and I'm looking for a back-up to carry on the boat. Not sure if I want to spend the $$ for the same prop. What would be a good alternative as a spare?
Thanks
2011 Tundra
cwag911
Re: Propeller
#2 Post by cwag911 » Mon Dec 15, 2014 5:15 am
Curious as to why you only run a 14p Enertia? Our boat is 22' and run a 15p Enertia on our 150 Honda. I get 39/40 @ 6100rpm.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
Re: Propeller
#3 Post by Bamaman » Mon Dec 15, 2014 7:20 am
Carl:
Your Honda has a 2.14:1 gear ratio where the Mercury has a 1.92:1 gear ratio. Your Honda prop spins just a little slower than the Mercury so that would make up for the 1" pitch difference.
My next door neighbor has a Verado 150 on a 22' Harris tritoon, and he too uses a 14 pitch Enertia.
cwag911
Re: Propeller
#4 Post by cwag911 » Mon Dec 15, 2014 9:19 am
Never thought about that.
Carl & Suzi
Re: Propeller
#5 Post by Bryden24shp » Mon Dec 15, 2014 10:40 am
Reiner wrote:I currently have an Enertia 15.125 x 14 SS prop on my 2014 Merc 150 HP outboard (part# 48-898988) and I'm looking for a back-up to carry on the boat. Not sure if I want to spend the $$ for the same prop. What would be a good alternative as a spare?
Thanks
Heck, I would just buy a cheap aluminum off Ebay, if its just going to be a "Get me back to the dock" prop. Make a holder for it by drilling a hole in a piece of plywood, insert a carriage bolt a little longer that the prop is through the back. screw it to the floor under a seat. Put your spare prop on it with the bolt protruding through the hub and use a large washer and nut to secure the prop down. No rattles or damage to the prop by moving all over the place when cruising. Cost? A few bucks, maybe! Just an idea that works great for me. Have built one for all my boats since the first one in the late 70's.
Re: Propeller
#6 Post by curtiscapk » Mon Dec 15, 2014 1:51 pm
Awesome freaking idea Bryan!
Reiner
Re: Propeller
#7 Post by Reiner » Mon Dec 15, 2014 3:15 pm
cwag911 wrote:Curious as to why you only run a 14p Enertia? Our boat is 22' and run a 15p Enertia on our 150 Honda. I get 39/40 @ 6100rpm.
It came with the boat and I haven't thought about changing things yet. Mine runs 37/38 mph based on GPS with bimini up and is ok with me.
Plus the other post about the different RPM's explains this too.
I'll go the basic aluminum prop route suggested and the mounting idea is pretty slick too.
Thanks for the info!
2011 Tundra
Re: Propeller
#8 Post by Bryden24shp » Mon Dec 15, 2014 9:06 pm
curtiscapk wrote:Awesome freaking idea Bryan!
Ha, I've had a few in days. Never seem to get me anywhere but in trouble! :lol3
