Which fishing seat mounts to use?
redbeard
#1 Post by redbeard » Sat Dec 27, 2014 10:31 pm
Well boys and girls here's a question for everyone. I received new fishing chairs for Christmas and will be mounting them on offset posts on my sun deck. Should I use 3/4 inch post or 3/4 inch threaded post or locking pin post, and should I use centered or offset base plates? Your advice and input is greatly appreciated and as always thank you in advance.
1stTimeToon
Re: Which fishing seat mounts to use?
#2 Post by 1stTimeToon » Mon Dec 29, 2014 2:41 pm
I just bought a project toon so I am speaking for my bass boat and what I plan on using in my project boat.......My bass rig has 3/4" threaded pins base which is what is the lock n pin. The base is 7" or 8" square and has 6 screws that attach to you deck. If you mount under your carpet they are almost invisible except for the pin hole. Either way they are fairly flush so they won't cause a trip hazzard. You can either use a threaded or non threaded seat 3/4" seat pole. The treaded gives you a nice solid pole, and the unthreaded will have a very slight play that you likely will not notice, but is still very stable.
good luck
If it swims I will try to get a hook in its mouth.
redbeard
#3 Post by redbeard » Mon Dec 29, 2014 5:08 pm
Thanks for the info that is what I was looking for I have only had the bell post for seats in my boats
#4 Post by curtiscapk » Wed Dec 31, 2014 7:02 am
Kenneth,
I am thinking about one of these for the bow Admirals chair.
http://www.basspro.com/Bass-Pro-Shops-O ... 212071541/
redbeard
#5 Post by redbeard » Wed Dec 31, 2014 3:11 pm
Yep ordered mind off of ebay today be here first of next week.
C_M_25
#6 Post by C_M_25 » Wed Dec 31, 2014 4:54 pm
Forgive my ignorance as my boat doesn't have fishing seats, but what is the benefit of the offset posts? What conditions would you need to use them?
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
redbeard
#7 Post by redbeard » Wed Dec 31, 2014 6:24 pm
It's to give you more leg room in my case the seat will be above the back of my back couch. When I rebuilt my boat I did not set it up to fish with but I find myself doing more and more fishing off of it. My front deck is way too small to fish from with a chair so they have to go on the rear deck.
C_M_25
#8 Post by C_M_25 » Wed Dec 31, 2014 6:30 pm
Can you post pictures when you get them mounted? I'm kinda in the same boat as you...
redbeard
#9 Post by redbeard » Thu Jan 01, 2015 12:03 pm
Yes I will but it might be a while but it will be done by April 15th opening day of spoonbill season.
