Jumper Pack
Reiner
Jumper Pack
#1 Post by Reiner » Sun Jan 04, 2015 3:41 pm
Couple friends from the SoCal Watercraft Club/Forum came across this Jumper Pack and the reviews are pretty good. I received mine today from Amazon and thought I share this here as well.
Here is the link to the company: http://antigravitybatteries.com/
Here is the Amazon link:
http://www.amazon.com/Antigravity-Batte ... ravity+xp1
Here is the link to the watercraft forum talking about it: http://www.socalwatercraftclub.com/foru ... php?t=4182
2011 Tundra
Re: Jumper Pack
#2 Post by HandymanHerb » Sun Jan 04, 2015 6:47 pm
I bought the 750 PEAK Amp Power Station, gives me a few uses for it camping too
The 750 PEAK Amp Power Station is an all in one jump-starter, inflator and mobile power outlet. It allows you to jump-start your own battery, pump up your tires and convert your vehicle’s 12V power source to a 110/120 Volt AC outlet and 1 Amp USB port by plugging into any cigarette lighter and/or 12 volt DC outlet. Specific features include:
750 PEAK amps
Exclusive Low Charge Alert (LCA) – warning that goes off when the jump-n 1 Amp USB
Digital LED display that shows:
Battery Life of the Jump-0starter
Volt meter reading of the dead vehicle battery
PSI reading
Durable High Impact resistant housing
100 PSI Inflator
100W Mobile power outlet
Reverse polarity indicator/alarm – Alarm and light if you do not hookup correctly to your vehicle (if hooked up incorrectly your battery could explode)
Built-in AC Charger (allows you to charge with most extension cords)
Sealed Lead-Acid Battery
12V outlet and 1 Amp USB
Best if used on 4,6, & 8 Cylinder gas vehicles or 4 & 6 cylinder diesel vehicles.
Re: Jumper Pack
#3 Post by margaritaman » Sun Jan 04, 2015 7:40 pm
Where did you buy it Herb?
chill'nthemost
Re: Jumper Pack
#4 Post by chill'nthemost » Sun Jan 04, 2015 9:22 pm
Reiner wrote:Couple friends from the SoCal Watercraft Club/Forum came across this Jumper Pack and the reviews are pretty good. I received mine today from Amazon and thought I share this here as well.
Those are the real deal. Cornwell Tools sold thousands of them when they 1st came out. We couldn't keep them in stock. They sold for a heck of a lot more off a tool truck. I was riding with a dealer one day when one of my dealers was demoing one. The owner said," if it will start that '76 Ford pickup I'll buy one". It had a 351 v-8 and I had him turn the key before we hooked it up, it was dead dead. It fired the pickup right up. The shop owner bought 3, one for him and one for each of his employee's. It's so damn small I would not of believed it until I watched it. Anitgravity has a quality line of products. This is cool because you can also charge your laptop, phone, etc.
Re: Jumper Pack
#5 Post by HandymanHerb » Sun Jan 04, 2015 10:46 pm
margaritaman wrote:Where did you buy it Herb?
BJ's had it for 75, but being Peak you should be able to find it anywhere, they sell a 900 with a 200 watt inverter too
They are call a power station
Pep Boys has the 900 for 110 bucks
rdeterman
Re: Jumper Pack
#6 Post by rdeterman » Mon Jan 05, 2015 3:57 pm
We use these at work all the time. I have used it to jump start our 2006 Chevy crew cab Duramax diesel. Works like a charm. Im going to buy one this spring to leave in the boat. Weights next to nothing and im sure we will use it for other things.
2014 Sylvan Signature 8523 LZ
2014 Yamaha F200 2.8l
Iowa
zoom650
Re: Jumper Pack
#7 Post by zoom650 » Wed Jan 07, 2015 3:54 pm
I bought this one a couple years ago at Northern Tool. Its served me well since.
http://www.northerntool.com/shop/tools/ ... _200422353
The first one I bought from Sam's club and it lasted years before finally dying.
Re: Jumper Pack
#8 Post by HandymanHerb » Fri Jan 09, 2015 1:48 am
I just seen another one from Northern, 1000 watt jump, 500 watt inverter,but that's not all
Navigational Lights Help Others Steer Clear
This fully portable unit is at home on the roadside as well as on the water or any other lowly lit area where additional traffic may be near. The integrated red and green navigational lights help indicate there's a boat/vehicle/person in the immediate path and helps route others safely away.
http://www.northerntool.com/shop/tools/ ... nt=234x104
BoatCop
Re: Jumper Pack
#9 Post by BoatCop » Fri Jan 09, 2015 5:19 pm
Lowes has a similar mini boost. $30.00 cheaper
http://www.lowes.com/ProductDisplay?par ... &cId=PDIO1
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
