Trailer Jack
Trailer Jack
#1 Post by curtiscapk » Thu Jan 29, 2015 10:22 am
My trailer jack broke at the end of the season. Which one would you guys get? The wheel is not really of use as it sits on gravel and never moves. I am thinking about the 5000 lb with the foot.
STEVEBRENDA
Re: Trailer Jack
#2 Post by STEVEBRENDA » Thu Jan 29, 2015 11:05 am
I bought a double wheel jack for my utility trailer. A wheel is important to me so I can nudge it a couple inches to get it lined up on the ball.
2014 Regency 254
Mercury 250L Verado
Re: Trailer Jack
#3 Post by curtiscapk » Thu Jan 29, 2015 11:44 am
Do you think the 1k will work or should I do the 1500# if I go with the wheel?
Re: Trailer Jack
#4 Post by RcgTexas » Thu Jan 29, 2015 3:23 pm
The one with the foot has a weld on piece, that's a little inconvenient, but the way to go as far as I'm concerned. I hate the saddle bolt kind, but that's just me.
get the 1500 # no matter
COTTS4x4
Re: Trailer Jack
#5 Post by COTTS4x4 » Thu Jan 29, 2015 4:50 pm
If you have a northern tool, harbor freight or tractor supply in town they should have what you need cheaper than bass pro.
[b][i]
[/i][/b]
steveiam
Re: Trailer Jack
#6 Post by steveiam » Thu Jan 29, 2015 5:26 pm
COTTS4x4 wrote:If you have a northern tool, harbor freight or tractor supply in town they should have what you need cheaper than bass pro.
That's what I did--
Re: Trailer Jack
#7 Post by Bamaman » Thu Jan 29, 2015 5:50 pm
Go with a double wheel fold up tongue jack. You can easily move your boat a few feet with an ATV or lawn tractor. I also have a 2" ball hitch on my ATV if I want to move it around the yard.
You have to be careful when pushing around any boat manually--or even an ATV. You can easily hurt yourself pushing and stopping. I keep wheel chocks handy to stop trailers from rolling into my house or other cars.
Re: Trailer Jack
#8 Post by ROLAND » Fri Jan 30, 2015 2:22 am
Craig, I know you said your boat and trailer sit on a gravel pad, but I think I'd still go for a trailer jack with a wheel....you never know if you're going to have to park your boat someplace where you might need to roll it around a bit.... better to have and not need than to need and not have.
Re: Trailer Jack
#9 Post by curtiscapk » Fri Jan 30, 2015 6:43 am
RcgTexas wrote:The one with the foot has a weld on piece, that's a little inconvenient, but the way to go as far as I'm concerned. I hate the saddle bolt kind, but that's just me.
I didn't even notice it wasn't a bolt on thanks everyone! Wheeled 1500 it is. :nana
Seon
Re: Trailer Jack
#10 Post by Seon » Fri Jan 30, 2015 8:03 am
I prefer the "drop leg" jack. One doesn't have to crank but a few times then pull the pin and the leg drops or can be manually retracted.
The down side is that it has to be welded to a plate that has to have holes drilled for the mounting bolts. I've got this type on my two boat trailers, utility trailer and camping trailer.
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
Bamby
Re: Trailer Jack
#11 Post by Bamby » Fri Jan 30, 2015 1:24 pm
Seon wrote:I prefer the "drop leg" jack. One doesn't have to crank but a few times then pull the pin and the leg drops or can be manually retracted.
I'm with you with the value and convenience of a drop leg jack design and I'd also like to let you know that bolt on applications are available. Dutton-Lainson Trailer Jack - DL22320
Re: Trailer Jack
#12 Post by RcgTexas » Fri Jan 30, 2015 7:42 pm
My problem with the saddle bolt units is the bolts rust so bad here on the coast. You can change them to SS but the just don't look as good to me. That little weld on piece can be put on in 5 minutes, and painted with cold galvanize will do just fine.
