Don't drive close to the ones that say ROCK on them..... to try and read it... your prop won't like it...
all kidding aside... I got close to this bouy to avoid other boats...I thought I was in the clear but ..NOPE... trashed another Prop... bad this time, the whole inner adapter shatered into aluminum puzzel peices.. the lower unit on the motor is fine..thanks to aluminum coming apart so easily
I can't believe I was able to limp her back to my lift.... kept her at 1000 rpm ( if it started to rise i shut her down) and the puzzel must have jammed enought to turn the prop... made it back...
I got the new prop assy ready for next Week end....
I'll attach pix when i get them sized...You like them
