Hour Meter
Reiner
Hour Meter
#1 Post by Reiner » Mon Mar 23, 2015 9:05 pm
I need to install an hour meter to track for maintenance. Just curious if those will work?
http://www.amazon.com/KEDSUM-Tachometer ... B00ACDP6YU
Also, do some of you use the steering wheel spinner knob for ease of control in tight spaces while docking. Saw one on a boat last weekend and it seemed easy to turn the wheel from one end to the other.
http://www.amazon.com/Type-AC50092-60-S ... B001PRX7WK
2011 Tundra
cleatus
Re: Hour Meter
#2 Post by cleatus » Tue Mar 24, 2015 7:01 am
Those hour meters can be mounted anywhere, depending on the length of the feed wire though. You could prolly mount it inside the cowl on the engine somewhere, don't know if they'll hold up to the heat, but they are sealed units.
and the wheel spinners work great, a bud of mine has a pic of a pin-up bikini girl embedded in his.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
babock
Re: Hour Meter
#3 Post by babock » Tue Mar 24, 2015 7:36 am
I just use my Rinda at the end of the season by scanning my motor! I know, a little expensive!
I would just use an hour meter the connects to your ignition at your dash.
Mercury 90 4 stroke
killerkernrich
Re: Hour Meter
#4 Post by killerkernrich » Tue Mar 24, 2015 8:15 am
I just put a "Tiny Tac" on my motor so far I like it.
PLP Member
NRA member
UFC fan
Reiner
Re: Hour Meter
#5 Post by Reiner » Tue Mar 24, 2015 8:28 am
cleatus wrote: and the wheel spinners work great, a bud of mine has a pic of a pin-up bikini girl embedded in his.
Already a reason to get one! :lol3 :lol3
2011 Tundra
BoatCop
Re: Hour Meter
#6 Post by BoatCop » Sun Mar 29, 2015 8:21 pm
With the Merc 150 you might want to go with the Smartcraft set up. An hour meter will be put into the ignition switch circuit, which will run the meter whenever the key's on. The Smartcraft will pull the hours off of the engine computer and give a score of other useful info.
Check this thread: viewtopic.php?f=2&t=20915
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
Reiner
Re: Hour Meter
#7 Post by Reiner » Mon Mar 30, 2015 12:35 pm
Thank you!
2011 Tundra
