Pontoon Boat Tie Downs on Boat Trailer
- 04Ram2500Hemi
Hi folks-
I've been around boats all of my life, however I've never had a pontoon boat up until this year (the wife convinced me that we needed to buy a Pontoon Boat, and I didn't think it was too bad of an idea). We ended up with a StarCraft Stardeck 216 StarLounger. I have the boat strapped to the front, and then a strap in the back of the boat on each side. My question is this- does anybody strap the front of their pontoon's to the trailer themselves? The boat seems to ride pretty well, but it moves a pinch more than I'm used to. Any help/thoughts would be greatly appreciated.
The Truck:
2012 Ram Power Wagon (not exactly 100% stock)
The Boat:
2015 Starcraft Stardeck 216 Starlounger
The Boat:
- NonHyphenAmerican
Re: Pontoon Boat Tie Downs on Boat Trailer
Call me anally retentive, but I hook a backup strap from the trailer frame to the front of the boat.
But then I put up with 35 years of the DOT checking for "Secured Loads" and firmly believe in backups for everything.
So that's just me.
So that's just me.
Yep, I ratchet strap my bow down to the trailer. I bolted 2 eyebolts underneath the bow on the crossmembers. Then ratchet strap to the inside frame of the trailer. Makes them trailer nice. I also ratchet strap the bow to the trailers bow stops, too. Takes the pressure off the bow strap. Actually, after cranking the boat on and securing the bow, I take the tension off the winch strap. I use heavy duty 3" ratchet straps. That self retract when you remove them. Been towing this way for years, back and forth to Lake of the Ozarks-Iowa. Makes towing more enjoyable without the boat bouncing around on the trailer.
Same here. Two trailering straps on the rear and a ratchet strap from the bow eye to the trailer in the front in addition to the winch strap.
We use a winch strap, a ratchet strap on the front across the bow, and 2 transom tie downs.
- 04Ram2500Hemi
I really appreciate the responses folks. If anybody can post some pictures of their setup that would really help.
The Truck:
The Boat:
The Boat:
I have some and I can post if I find my thumb drive!04Ram2500Hemi wrote:I really appreciate the responses folks. If anybody can post some pictures of their setup that would really help.
Look at your hand.Bryden24shp wrote:I have some and I can post if I find my thumb drive!
Notice those four long wiggly parts.
Those are fingers. Ignore them.
Now, notice that shorter, fatter wiggly part.
That is your thumb.
Does that help?
BobG......
Here are some pics of my old Manny strapped to the trailer back in 2008. I do the Premier differently. I'll get some pics of it, later and post... I miss that ole boat!
- straps 004.JPG (76.29 KiB) Viewed 8790 times
- straps 002.JPG (75.26 KiB) Viewed 8790 times
- straps 003.JPG (76.31 KiB) Viewed 8792 times
- straps 001.JPG (65.61 KiB) Viewed 8792 times
I use 2 transom straps on the stern (although I need to mount eye bolts to the trailer to give a better place to attach to). I did add 2 eye bolts to the front of the trailer that I attach 2 transom straps to -- but I need to attach eye bolts to the cross pieces on the bolt instead of using the hook points on the tips of the toons.
- tie-down3.jpg (112.37 KiB) Viewed 8779 times
I have one of these bolted to the center rail on my trailer and it goes up to my center toons eye. On my old pontoon it went to the center loop just to hold the front end down. Its called a boat buckle, and works great.
I've used four straps when trailering any distance since near day one. They make the boat much more stable over the road.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
Like the OP I did not like the bounce in the front of my boat when trailering either. We had two transom straps on the stern, but just the winch strap on the front. I found 3 more transom straps and just hook one on each pontoon and down to the trailer and no more bounce. They take about 20 seconds each to put on, so it's well worth it.
2007 South Bay 925 Tri-toon
5.7 Volvo I/O
5.7 Volvo I/O
- 04Ram2500Hemi
Thanks for the pictures guys. That gives me some good ideas!
The Truck:
The Boat:
The Boat:
Great posts and great ideas.... I think that you all have solved my problems... nothing better than learning from all of your experience.
Thanks,
Bill
Thanks,
Bill
