Hydro Stabilizer...
Hydro Stabilizer...
Are these worth taking off my old engine and putting on my new-to-me one???
- IMG_2263.JPG (600.23 KiB) Viewed 4005 times
Re: Hydro Stabilizer...
I had one of those on my previous Four Winns V hull as it was slow to plane or didn't plane until I hit 20 mph. Made tubing and low range cruising much more enjoyable with the fin on. Since pontoons have little to no bow rise, I see no reason for it. Others may have a different experience though.
27" RPT tubes w/underskinning
2014 115hp Mercury 4 stroke
Joseph Elliott
They are designed to lift the stern of the boat higher, which in a v-hull will help with planing. Their design creates lift in the same way an airplane wing works. I don't know if they would help or hinder a pontoon boat but I have never seen one on one either.
Alberta, Canada
Home made 16' pontoon, 1980 60HP Johnson- work in progress
It helps pushing water back to the prop if you are having blowouts or cavitation problems.
